Convey some data from the sensors of the secondary station to the primary station
Posted: Tue Sep 22, 2020 6:22 pm
Hello.
I have a meteobridge PRO-RF with 2 registered weather stations.
The main one is a Davis Vantage VUE, the secondary a Fine Offset WH2650 with additional sensors, such as the Froggit DP60 lightning sensor and the Froggit DP100 Soil Moisture.
It seems that you can see all the data of both stations well but I would like to ask you a question: Is it possible to convey the data of the lightning sensor and the Soil Moisture together with the data flow of the main station (Davis VUE in fact)?
I have my portal in Meteotemplate and I would like to add these sensors to the standard information sent by the meteobridge.
Does anyone know how to do?
