SFTP server on RPi?
Posted: Sat Nov 28, 2020 1:08 pm
by andlil
Now that it is possible to disable SMB, would it be possible to get an SFTP-server instead?
Feels more compatible and versatile, I realize that it was a constraint when running on router hardware but now we have "infinite" memory and disk space with the RPi.
Best regards
//A
Re: SFTP server on RPi?
Posted: Sat Nov 28, 2020 1:48 pm
Can you provide a compellling use case that cannot suited with installed technology?
Posted: Sat Nov 28, 2020 2:45 pm
by andlil
Yes, I have my Meteobridge installed at a remote location with 3G connectivity. When I connect over the IPSec tunnel that is established it is very slow, just loading the /data/templates directory takes seconds, same with transfer to and from the share. If I forget to disconnect the share and a file explorer window is open in the background, it will refresh constantly and eat up my data allowance.
I can use SCP to transfer files but I prefer a nice GUI like Cyberduck or Filezilla.
OK, put it this way;
What happens if I decide to uninstall the samba4-server and samba4-libs using opkg and install openssh-sftp-server instead, will that break anything other than SMB and possibly your willingness to support such a configuration?
