Meteoclimatic user migrating from meteohub
Posted: Sun Jan 24, 2021 3:15 pm
by ipe
I would like to migrate from Meteohub to Meteobridge, but I'm having some problems to upgrade, while keeping the consistency of my data:
1. The generated template uses UPD time. I would like to use UTC. I even can't select UTC as the time of my system
Solution: If I don't set any timezone, it uses UTC as default. But I have a warning, that I must set any timezone (different from UTC)
2. Is it possible to use awk scripts to callibrate sensors? ax+b is't enough in some situations.
Thank you so much, Boris
Re: Meteoclimatic user migrating from meteohub
Posted: Sun Jan 24, 2021 7:26 pm
by AlaskaWX
ipe wrote: Sun Jan 24, 2021 3:15 pm ...
You could create a plugin weather station using an awk script. See this post for info on how I approached the problem of calculating the wetbulb temperature: https://forum.meteohub.de/viewtopic.php?f=61&t=15468.
If you know awk well enough, you could use this technique as a basis for doing just about any calculation with any input sensor values and output the new value to a new virtual sensor of your choice.
Posted: Sun Jan 24, 2021 8:05 pm
by ipe
Thanks!!!!!!!!!!
