The story is a bit more complex than that I fear.
Today I had three (3) lightning events. This is properly shown in the live data (assuming that energy means the number of strikes [per what time unit ?]) - of course, because this is what the GW1000 provides. Meteobridge hasn't done anything yet but pulling the data from the console.
- MB-lightning_20210131_01-2.JPG (72.68 KiB) Viewed 4956 times
It will now remain in the live data for some time - but in the min/max, this is already a MB process result, they are going to disappear next day unless there's a new event until then.
BUT
in the data history there is nothing or strange entries (or only crosses in the mini graph) visible:
(in the database [not in the history view, in the table light0energy_hour] only one entry, value 1000 (probably because the field unit is strangely mm, and 1 x 0.001 = 1 - but only 1, not 3) even though the events were in the same hour; there are no more DB entries either; in the light0energy_minute table there is also only one entry, value 1000)
In the light0total day table: no entry, light0total_hour one entry value 0 (they were 3 though), in the light0total_min table, one entry, value 1000
- MB-lightning_20210131_03.JPG (130.04 KiB) Viewed 4956 times
- MB-lightning_20210131_04.JPG (151.51 KiB) Viewed 4956 times
- MB-lightning_20210131_05.JPG (150.49 KiB) Viewed 4956 times
in the exported minute data, the lightning there are values - see below
but either there are entries for 6 consecutive minutes - no idea where they are from - as they don't appear in the persistent database
(maybe [speculation] the values come from the RAM DB and these values are somehow not not properly calculated and written to the persistent database)
# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall00, Solar [W/m2], PM25(1) [ug/m3], PM25(2), extra-temp1 [°C], extra-hum1 [%], extra-temp2 [°C], extra-hum2 [%], extra-temp3 [°C], extra-hum3 [%], extra-temp4 [°C], extra-hum4 [%],soil moisture (1) [%], soil moisture (2) [%], soil moisture (3) [%], soil moisture (4) [%], soil moisture (5) [%], lightning total, lightning distance, lightning energy, WH45-temp-in, WH45-hum-in, WH45-CO2, WH45-PM25. WH45-PM10
2021-01-31,11:32,0.8,95,0.1,999.8,2.4,3.4,264,0.0, 61.50, 9.0, 30.0, 0.8, 94.0, 2.5, 99.0, 0.3, 97.0, 0.8, 99.0,41, 50, 69, 56, 68, , , ,20.9, 49.0,730,5.6, 5.6
2021-01-31,11:33,0.8,95,0.1,999.9,1.6,3.4,248,0.0, 64.25, 9.0, 30.0, 0.8, 94.0, 2.5, 99.0, 0.3, 97.0, 0.8, 99.0,41, 50, 69, 56, 68, , , ,20.9, 48.5,743,4.5, 4.2
2021-01-31,11:34,0.8,95,0.1,999.9,2.1,3.7,264,0.0, 67.25, 9.0, 30.0, 0.8, 94.0, 2.5, 99.0, 0.3, 97.0, 0.8, 99.0,41, 50, 69, 56, 68,
1, 27, 1,20.9, 48.0,738,4.2, 3.5
2021-01-31,11:35,0.8,95,0.1,999.9,2.3,4.9,279,0.0, 66.00, 9.0, 30.0, 0.8, 94.0, 2.5, 99.0, 0.2, 97.0, 0.8, 99.0,41, 50, 69, 56, 68,
1, 27, 1,20.9, 48.0,727,4.0, 3.2
2021-01-31,11:36,0.9,95,0.2,999.9,1.3,3.9,267,0.0, 67.50, 9.0, 30.0, 0.8, 93.0, 2.5, 99.0, 0.2, 97.0, 0.8, 99.0,41, 50, 69, 56, 68,
1, 27, 1,20.9, 48.0,699,4.1, 4.0
2021-01-31,11:37,0.9,95,0.2,999.5,1.9,4.6,242,0.0, 73.80, 9.0, 25.0, 0.8, 93.0, 2.6, 99.0, 0.2, 97.0, 0.7, 99.0,41, 50, 69, 74, 68,
1, 27, 1,20.9, 48.0,713,6.1, 5.2
2021-01-31,11:38,0.9,95,0.2,999.9,1.0,4.5,276,0.0, 80.80, 9.0, 25.0, 0.8, 93.0, 2.6, 99.0, 0.2, 97.0, 0.8, 99.0,41, 50, 69, 87, 68,
1, 27, 1,20.9, 48.0,725,6.2, 5.5
2021-01-31,11:39,0.8,95,0.1,999.8,1.7,2.7,248,0.0, 93.50, 9.0, 25.0, 0.8, 94.0, 2.6, 99.0, 0.2, 97.5, 0.8, 99.0,41, 50, 69, 86, 68,
1, 27, 1,20.9, 47.5,640,5.3, 4.5
2021-01-31,11:40,0.8,95,0.1,999.9,1.4,3.0,232,0.0, 102.00, 9.0, 25.0, 0.8, 94.0, 2.6, 99.0, 0.2, 98.0, 0.8, 99.0,41, 50, 69, 85, 68, , , ,20.9, 47.0,649,4.5, 4.1
2021-01-31,11:41,0.8,96,0.2,999.9,0.9,2.3,261,0.0, 104.50, 9.0, 25.0, 0.8, 94.0, 2.6, 99.0, 0.3, 98.0, 0.8, 99.0,41, 50, 69, 85, 68, , , ,20.8, 47.0,607,10.3, 8.2
whichever of the three lightning sensor descriptor values is what (this, i.e. the name, can be sorted out easily I guess), but when the values are not, not completely or/and not properly recorded in the database, they cannot be properly retrieved either.
For my three lightning events, there should be (reasonable) entries in the _day, _hour, _min tables of each, which correspond to:
# of strikes per day
# distance of strike (accuracy in the minute time windows)
# record of last and closest strike
as the events are shown in Ecowitt.net
- MB-lightning_20210131_06.JPG (20.35 KiB) Viewed 4956 times
Now, after one day the data have disappeared from the min/min history where in my opinion that should remain.
Also, later on, nothing in the database (history).
@Boris: you want to have a copy of the database or access the system ? Let me know.
