Another Weather34 issue on MB/RPi **misleading post**
Posted: Tue Jan 26, 2021 4:49 pm
by Gyvate
I've posted that in the Weather34 template thread, but not sure to what extent it will be noticed there ...
I'm using Meteobridge on RPi and included is a W34 version - 9.34 as the screen says.
What is missing is the history - there is no history button visible to click on - and there's no history to be displayed either.
Even though the files and year directories are there ../PWS/MB2/weather34charts/... the yearly or monthly csv files are not updated nor are the daily files being created.
Is this a bug or a feature ? Maybe no history meant to be shown on a MB/RPi ?
Or is there some special customizing to be done by me ?
Beyond the standard setup, some special option ?
I'm running a W34 version fed by MB Pro on a web site which works perfectly - it also has history.
Another Weather34 issue on MB/RPi **pseudo solved **
Posted: Fri Jan 29, 2021 11:44 am
by Gyvate
I received the following reply by Boris in the general Weather34 thread:
"The dashboard included with the RPI does not show the weather34 specific graphs.
If you are looking for a complete weather34 installation you have to set this up on some webspace your own and feed it with data from Meteobridge."
I did some digging and you can have it easily run on MB/RPi.
There are no known (or revealed) reasons, not to have this functionality on MB/RPi.
And you don't need an extra web space or web server - it's all on/in the RPi.
Even though I have one since quite some time: https://meshka.eu/Weather34
Look and see the difference - there the Almanac is active.
And it could be also like this on the MB/RPi - if you want to have it.
If you are interested in the Almanac functionality on your MB on RPi, (and if you are a WXforum member) PM me there.
Same avatar name.
The PM system here doesn't work properly, and the admin has no time to look into it.
Re: Another Weather34 issue on MB/RPi **pseudo solved**
Posted: Fri Jan 29, 2021 11:57 pm
@Gyvate: Please differentiate between additional features you would like to have and issues.
The embedded weather34 cockpit is a SUBSET of the general weather34 options. It does not include graphs.
I think it provides pretty much coming there with zero install hassle.
When you think you have a better solution feel free to provide AND TO SUPPORT your stuff. I will not do.
Anybody installing this is asked to reach out to user Gyvate for support. Once having installed his "addons" I am 100% out of support.
Good luck!
