Under reporting of rainfall in exports and html (modified se
Posted: Tue Jul 22, 2008 5:42 pm
I have a modifying factor of 0.342 on rain0
I can manually calculate the recorded rain over a period by checking raw sensor readings then adjusting by that factor.
If I then compare that to data output by Meteohub in various forms I find discrepances:
a) The logging protocol is producing the correct total rainfall figures in WD. :)
b) The WSWIN export is producing low figures. :(
c) [day1_rain0_total_mm] is producing the same figure as the (export based) WSWIN 'today'. :(
Taking a quick look at the WSWIN export lines, I notice that every tip now seems to be reported as 0.3mm, which would lead to a rounding error.
I'm sure that earlier exports used to produce a tip pattern in which there was the occasional 0.4mm.
Is this possibly related to the recent changes in rainfall handling?
