				Change Dashboard. **solved**
				Posted: Wed Feb 24, 2021 9:18 am
				by engelbert
				Is it also possible to change the dashboard of the meteobridge pro. E.g. to delete the min and max values or to add extra sensors ??
see
https://weerstationbijdetoren.nl/nieuw/dashboard.html
Thanks in advance.
El Engelbert
				Re: Change Dashboard
				Posted: Thu Feb 25, 2021 11:35 am
				by Neco
Hi
I don't have an answer to your question, but, how did you get the dashboard on your website? Via ftp upload?
				Posted: Sat Feb 27, 2021 6:46 am
				by marco
Hi Engelbert
Not sure if I get your question right. But the short answer is yes. The dashboard.html is just an example how you can present "any" data of your meteobridge. Just create your own (e.g. my-dashboard.html) file, and fill it with the available variables you like. Than place it in your "templates" folder, and use the integrated pushservices from meteobridge. A little html-knowledge would help, to accomplish the task.
hope that helps marco
