failed to copy image onto industrial micro SD
Posted: Mon Jun 14, 2021 10:49 am
by ashico
I had ordered an industrial micro SD card, as your recommendation,
ATP AF2GUDI (microSD Card, 2 GB, SLC Flash, -40°C – 80°C)
But it's failed to copy image into, and flash with the red light at the RP3+.
I'd tredy allmost every single SD image copier, and it's seem to be completed, but not booting inside the RP.
*Just to mention, that it's allready work with regular sd card.
Any advice?
Ashi,
Re: failed to copy image onto industrial micro SD
Posted: Mon Jun 14, 2021 7:52 pm
by BigAlT
How does the red LED on the RPi behave when first booting up right after inserting the freshly copied image ?.
“ Having copied the disk image to the card it just needs to insert the card into the Raspberry Pi, connect it with an Ethernet cable to your LAN and to power it up. Your card is flashed fine when the red LED starts blinking slowly and then changes to fast blinking after a while. When the red LED reaches steady on, your Meteobridge has successfully reached out to the Internet, has loaded the application stack and is ready to go. When you don't see the blink -> fast blink sequence, your low level copying of the Meteobridge image to your microSD card has failed. “
If the blink pattern isn’t correct try and View the contents of the copied micro SD card on a computer ( laptop or desktop ) and see if the files are there.
Try and completely reformat the micro SD card to FAT32 and then do a new low level copy of the Image to the micro SD card. There is always the possibility that the card is defective though that is probably remote.
PS,
This is not the correct sub forum for the RPi Meteobridge. This forum is for the RPi Meteohub which is a completely different software. If you are trying to load the Meteobridge image for your RPi you should post this issue in the MeteobridgePRO/NANOSD/RPI/ Discussion forum viewforum.php?f=61
