How to add new Ambient WS-2902C
Posted: Thu Jul 08, 2021 12:32 am
by captgadget
I already have a Davis WLL as the primary. I see there is a box to "add weather station" the WS-2902C is not on the list. So just wondering if I'm out of luck on this. Should add I'm running a Raspberry PI4.
Re: How to add new Ambient WS-2902C
Posted: Thu Jul 08, 2021 11:35 pm
I don't think this station provides any data in your LAN/WLAN. SO there is no option to support it.
Posted: Fri Jul 09, 2021 9:54 am
by pscho
May be you can try " Ventus W 835 " instead of Ws2902C to provide data to meteobridge ?
Paul
Posted: Fri Jul 09, 2021 12:57 pm
by wvdkuil
captgadget wrote: Thu Jul 08, 2021 12:32 am
The Ambient WS-2902 C can not be read
directly by a Meteobridge or other weather-programs.
This station is another Ecowitt rebadged device. It is using Ambients own firmware in the console.
You need to add a (relative inexpensive) Ecowitt GW1000 to get the data from the outside and inside sensors of the WS-2902 C.
That Ecowitt GW1000 uses a local API which is fully supported by Meteobridge, Weather_display, Weewx and even some templates.
You can add extra sensors (lightning, CO2 a.s.o. which are not supported by your Ambient console.
Read here:
https://www.ecowitt.com/shop/goodsPage/1/31
You should order the US frequency.
Posted: Fri Jul 09, 2021 3:42 pm
by captgadget
Thanks for all your help. I now understand why it is the way it is. Thanks again.
Posted: Sat Oct 23, 2021 3:22 pm
by captgadget
Help Wim, what part am I looking for?
Posted: Sat Oct 23, 2021 4:13 pm
by wvdkuil
captgadget wrote: Sat Oct 23, 2021 3:22 pm
https://www.ecowitt.com/shop/goodsDetail/107
The GW1100 is probably also available from Amazon and others.
https://www.amazon.com/Ecowitt-Weather- ... B0978XLG8T
Regards,
Posted: Sat Oct 23, 2021 7:55 pm
by captgadget
I've read through the manual but I don't understand how this is going to send my weather info from my Ambient WS-2902C to my Meteobridge. Sorry for being so dense.
Posted: Sat Oct 23, 2021 9:52 pm
by wvdkuil
captgadget wrote: Sat Oct 23, 2021 7:55 pm
Meteobridge and other weather programs can read the data from a GW1100.
You define a second weather station and the GW1000 is in the selection drop-down.
Regards, Wim
Posted: Sat Oct 23, 2021 10:52 pm
by captgadget
Ok, now I understand. Thank you
Posted: Sat Oct 23, 2021 10:58 pm
by captgadget
So I can leave my WLL there and add a second station then?
Posted: Sun Oct 24, 2021 8:24 am
by wvdkuil
captgadget wrote: Sat Oct 23, 2021 10:58 pm
Yes you can.
But you also has to think
why you want to do that.
It is "complex" to specify/setup those combinations, but it can be useful.
In my case I have a Vantage VUE , which has no UV and solar.
I added a second station to add that station UV and solar to my uploads.
