Solar/UV sensor data via anemometer transmitter. **solved**
Posted: Tue Sep 14, 2021 11:57 pm
I am new to Meteobridge. In my configuration the following Davis Vantage Pro 2 sensors are connected to an anemometer transmitter kit: wind, solar, UV. In my Meteobridge Pro the sensor configuration (configured in tab "Station" -> "Primary Station") is set as follows: Transmitter #1: ISS; Transmitter #2: Wind Station.
As a result, my MB only receives the wind data, but none of the solar and UV data. If I set Transmitter #2 to "Solar Station" or to "UV & Solar Station", the MB receives solar data correctly, but none of the wind and UV data.
According to this post: viewtopic.php?p=27548#p27548 in the forum, I'd expect that MB Pro can process all connected sensors correctly. But how? Can anyone help?
