Davis WLL --> Meteobridge RPI --> WSWIN issue
Posted: Sat May 07, 2022 1:04 pm
by Robert2011
Hello all,
after replacing my old Oregon WMR-200 with a Davis Vantage Pro 2 + WLL 6100 last year, I use Meteobridge on a Raspberry Pi 4 Model B to transfer weather data to WSWIN, among other things. Since then, this has been working largely without problems, but since 1 ... 2 weeks there have been gaps in the WSWIN data feed, the cause of which is not entirely clear to me:
Although the raw data displayed by MB are regularly updated within a minute, the view of the minute data and later also the WSWIN data feed (import.csv) show gaps, sometimes one minute value is missing, sometimes 2-3 minutes in a row.
What could be the reason for this? I haven't really changed anything about the structural situation and thus the reception quality.
If this is so normal and simply did not occur before for whatever reason, can the WSWIN data feed be configured in such a way that when measured values are missing, the last value is simply entered until a value is received again?
Thank you
Robert
Re: Davis WLL --> Meteobridge RPI --> WSIN issue
Posted: Sat May 07, 2022 3:28 pm
Do you have "per minute" data storage active on the Meteobridge?
If so it might help to use the "data edit" tab to see if Meteobridge does have these gaps in its data or if it is more a data export issue when feeding WSWIN.
Re: Davis WLL --> Meteobridge RPI --> WSWIN issue
Posted: Tue May 10, 2022 10:43 pm
by Robert2011
If data storage "per minute" is active on Meteobridge the gaps are also there.
Today I could see this gap also on live data at least once.
Is it possible that the WLL has a hardware problem or are these signal problems that were not there before?
Can the WSWIN data feed be configured in such a way that when measured values are missing, the last value is written to WSWIN data feed until a value is received again? May be for an adjustable maximum time?
Posted: Mon May 23, 2022 7:38 pm
Are there other programs on your desktop i.e. that also read data from WLL in parallel? This might pull the WLL into blocking mode here and there.
