New tp-link won't connect to router. **solved**
Posted: Thu Mar 16, 2023 11:25 pm
by wthrmn654
So I bought a new tp link and it to won't work, easily so far, to connect to an existing router. It only connects with direct cable but not wifi.
The router isn't a mesh router, that I can see. It's Linksys EA8300
Anyone have any ideas? It has worked for months/ years without issues and now issues.
Re: New tp-link won't connect to router
Posted: Fri Mar 17, 2023 1:09 pm
by wthrmn654
I should also mention that I must of not done the reset procedure correctly the first time, thankfully. I was able to get the first unit connection settings to reset to default
Both work correctly when directly wired.
No idea what changed/ happened to make it not cooperate suddenly.
Still any comments, ideas, or suggestions are needed!
Posted: Tue Mar 21, 2023 1:26 pm
solved with latest update
