E-Mail error **solved**
Posted: Wed Nov 01, 2023 6:02 am
by Zedekia
Hello together,
I‘ve a MB2 Pro.
My email settings no longer work. Here is the error message: Error: Writing settings failed (/root/meteobridge.conf): move of /var/run/.meteobridge.conf to /root/meteobridge.conf failed: No such file or directory
What can I do?
Update: the settings are no longer saved. Big problem, because no changes are possible.
cu.
Zedekia
Re: E-Mail error
Posted: Wed Nov 01, 2023 1:20 pm
What does "http://ip-of-meteobridge/cgi-bin/system.cgi?df%20-h%20" report?
Can you give me remote access? Please mail credentials to "info(at)meteobridge.com".
First try to reboot to load newest application versions. I think it will already solve the problem.
Re: E-Mail error
Posted: Wed Nov 01, 2023 7:15 pm
by Zedekia
Thank you for your help. E-Mail is on the way.
The meteobridge have the newewst firmware.
cu
Zedekia
Re: E-Mail error
Posted: Wed Nov 01, 2023 9:56 pm
Reason was a filled up flash file system, presumably caused by some user driven install or upgrade attempt on shell level.
I cleaned up and system is fine again.
My intent is not to blame anyone. But in general, logging in via ssh and installing something from the openwrt repository is a very bad idea. Please don't do. If you can't resist, please reset to factory default when things don't work anymore after such an attempt.
Re: E-Mail error **solved**
Posted: Sat Nov 04, 2023 9:05 pm
by Zedekia
Thank you for your help. It is true that I used an ssh client to mount my external USB. Of course I will not do this again. Thanks again for your support and sorry for the late reply.
cu Zedekia
