Deleted meta chart. **solved**
Posted: Tue Dec 12, 2023 11:42 am
by zakos52
I have created a meta chart for testing, and now I want to delete it. How is this done?
Re: Deleted meta chart
Posted: Tue Dec 12, 2023 11:58 am
by Mattk
Since FW released around August 2023, delete routine is available under System>Administration/Maintenance/Media Access [Download or Delete files] or you can access the file shares directly via SMB
Posted: Tue Dec 12, 2023 3:21 pm
by zakos52
I select the meta chart and press delete, the message that it has been deleted appears, but the file remains undeleted!
Posted: Tue Dec 12, 2023 11:00 pm
by Mattk
Is the file still loaded in any of the Graphs tabs?
Posted: Wed Dec 13, 2023 1:50 am
by zakos52
The file exists as a name without containing any data
Posted: Sat Dec 16, 2023 2:53 pm
Thanks for spotting this. I tested a bit and it turned out the files that have a space character in their name are not deleted. Reason is that the file name handed over as URL parameter does not get correctly url decoded. I just released an update that should have this fixed.
Re: Deleted meta chart. **solved**
Posted: Sun Dec 17, 2023 2:55 pm
by zakos52
With the last upgrade I deleted the file.
Thanks for the prompt response
