Foscam R2M Camera
Posted: Fri Dec 29, 2023 9:57 pm
by G4MHJ
Has anybody managed to get this model of camera working with a NanoSD.
I have managed to get a green tick for
http://192.168.1.113:88 on the Station/Cam page.
If I click on the camera/internet icon to the right of that window it tries to open a page 192.168.1.153/aircam.jpg but nothing is found. Maybe iit never will as I probably need to do something else.
If anybody can assist here I would be most grateful.
Re: Foscam R2M Camera
Posted: Tue Jan 02, 2024 2:26 pm
by hymrog
Hello
Try this
http://ip address:port/cgi-bin/CGIProxy.fcgi?cmd=setSubStreamFormat&format=1&usr=xxx&pwd=xxx
g
Posted: Wed Jan 03, 2024 11:35 pm
by G4MHJ
Thanks hymrog. That URL was accepted into Station/Cam giving a Green Tick. I am not sure what else I need to do produce a static url for an ftp. Also the url mentions substream and I have a choice in Foscam configuation or Cover and substream but I don't know what this does. I have it as Cover currently.
Posted: Wed Jan 03, 2024 11:57 pm
by hymrog
Hello -
There are two streams for the Foscams, the main stream and the substream. The substream uses less resources. I am not really sure what you are trying to do but if you set the url I provided, along with appropriate credentials, on the Cam tab and you click the Camera picture on that page you should get a static image of your camera.
Have a look here. This is a list of various commands that can be used with most Foscam cameras.
https://www.foscam.es/descarga/Foscam-I ... .11.06.pdf
This might help as well:
https://www.meteobridge.com/wiki/index. ... e_Handling
g
Posted: Sun Jan 07, 2024 11:20 pm
by G4MHJ
Thanks very much for those links. I have always found anything to do with webcam images too complicated these days!
My intention was to get a periodic still image to my website, either a new page or part of a PWS or Weather34 template. I currently have the Foscam VMS running to produce video and snapshots actioned by movement but of course these produce files with date and time filenames. I also record 24/7 data to my Synology NAS system for a maimum period of a few days before being over written.
I had never seem the foscam CGI pd before
The Station/Cams screen still gives no image (even with a green tick), just a small blue icon using Safari on a Macbook.
Posted: Mon Jan 08, 2024 11:24 am
by G4MHJ
hymrog
Some partial success using a URL from the Foscam pdf
http://192.168.1.113:88/cgi-bin/CGIProx ... pwd=xxxxxx (pwd removed) entered into my browser gave a snapshot. My question now is, is there a service needed to get this to my website. I assume I can ignore the station/cam entry now.
Thanks for your patience.
Posted: Tue Jan 09, 2024 6:18 pm
by hymrog
Hello
You will need to do the following:
1. On the Weather Network tab select Meteobridge Weather Camera
2. Set your upload interval and template
3. Under the services tab select Camera FTP upload from the Select Service drop down menu
4. Set up your FTP using the following instructions:
https://www.meteobridge.com/wiki/index. ... TP_Uploads
5. Enter the path to your storage location as outlined here:
https://www.meteobridge.com/wiki/index. ... mera_Event
g
