Resize SDCard on Raspberry Pi
Posted: Mon Jan 15, 2024 11:35 am
by nordblick
Hey Guy,
i am using an old RPI 3b with an 16GB Card. Everything works fine, but I want to install some python modules on my raspberry. Unfortunately the 16GB card will noch automatically resized from Meteobridge firmware/OS. Is there a way to use all of my SDCard memory?
Cheers,
Olli
Re: Resize SDCard on Raspberry Pi
Posted: Sat Jan 20, 2024 7:52 am
by Gyvate
This is exactly what is mentioned in the Meteobridge WiKi - a MB on RPi is not meant to be used for other purposes than for a weather data server.
You can try to tweak around with openWRT, but will probably not have much success.
It's, however, no surprise as this is explicitly mentioned.
quote from https://www.meteobridge.com/wiki/index.php/Hardware
"As Meteobridge does come with its own openwrt-based operating system, installing additional SW onto the Meteobridge will not be possible in most cases. The idea of Meteobridge is to convert your Raspberry Pi into an exclusive weather data server. It is not meant as an experimental platform to try out generic Raspberry Pi stuff. "
Posted: Thu Jan 25, 2024 2:00 pm
by nordblick
I already read that. ;)
It's just a bit "useless" for me to collect data from my weather station with a complete separate device (that is also an RPI). The only purpose is to receive data and wait for meteobridge to fetch it. Would be easier to put that single python script on my bridge instead. Meteobridge is still a weather data server. :D I just try to avoid the second RPI but the disk size of meteobridge isn't big enough to instal all required python stuff.
Posted: Thu Jan 25, 2024 6:52 pm
by Gyvate
feel free to use a Python script for your purpose.
Meteobridge however is a slightly more powerful tool that can do things a simple, single Python script won't be able to do.
You'll need significantly more Python code. Plus, the philosophy of MB has always been to be an appliance for collecting, storing, analyzing, depicting and sharing weather data. Pretty much beyond just collecting data and storing it. But then, specialized on collected weather data.
Provided you know, appreciate, and want to use these features.
But if your needs are served with the mentioned single Python script, go for it. Then probably Meteobridge is then just overkill for you.
Posted: Tue Jan 30, 2024 10:53 am
Meteobridge supports bash scripts (to be precise ash scripts). Using ash instead of python might be a challenge. Meteobridge on RPI also has php installed, I guess this has all the power you need. So say good-bye to python copy-and-paste and you should be fine.
