Forecast variable. **solved**
Posted: Fri Jan 26, 2024 6:06 pm
by ramon.sala
I'm trying to configurate an even that sells a email with the forecast for the day, but actually it doesn't work. My meteobrigde gets the data directly from the ISS. I think it has to get the data also from de console as I suppose the forecast is computed by the console. So I configured the console as reemiting data in transmitter 2 and the meteobridge gets data from transmitter 1 in addition to transmitter 2.
Re: Forecast variable
Posted: Fri Jan 26, 2024 10:44 pm
by Mattk
Forecast are only available if using a Davis station and only if the MB connects direct to the console.
Posted: Tue Jan 30, 2024 3:23 pm
by ramon.sala
Thanks Mattk for your answer. I connected meteobridge with the console (in relay mode via transmitter 2) and it doesn't work either.
Posted: Tue Jan 30, 2024 8:10 pm
by Mattk
ramon.sala wrote: Tue Jan 30, 2024 3:23 pm
No, Re-transmit from the console is basically an ISS with a different TX ID so no difference to that of the main ISS. For a MB to read a Davis forecast you need to have a physical cable connection through a logger
Posted: Tue Jan 30, 2024 8:34 pm
by ramon.sala
Ok. Thanks again. I'll try.
