Database Backup failed on RPI MeteoBridge **solved**
Posted: Tue Feb 13, 2024 5:09 pm
by xray77
When I try to initiate a backup of the database on my MB RPI, I am first asked whether I really want to make a backup on the connected USB stick (complete new Intenso 64GB stick, FAT32). However, this error message then appears regularly in the system log:
backup (13.02.2024 16:02:52): error on mount: mounting /dev/sda1 on /tmp/backup failed: Invalid argument
How can I make a database backup? On my MB NANO-SD this works without any problems on the built-in micro SD card, why does it have to be done on a USB stick on the RPI-MeteoBridge?
Re: Database Backup failed on RPI MeteoBridge
Posted: Tue Feb 13, 2024 9:16 pm
by Mattk
The intenso 64GB is straight out of the packet, default format as in you never specifically formatted it FAT32 either?
Posted: Tue Feb 13, 2024 10:10 pm
by xray77
Hello Mattk,
Yes, it's straight out of the box, Windows 11 says the stick is FAT-EXT formatted, i.e. FAT-Extended. Win 11 does not even give me a choice to format to FAT32. What can i do now? Thanks for help!
regards
Michael
Posted: Tue Feb 13, 2024 10:20 pm
by Mattk
I am not RPI savvy but sounds like the same backup approach as the MBPro, plug a brand new USB stick into the front port of a MBPro and backup writes to that. Yes NanoSD is different, writes to backup folder on MicroSD
Unsure if the 64GB is a factor or what the FAT-EXT is about, don't run Win11 either? Have never tried that size, typically run 16GB straight of of the packet on the MBpro
Posted: Tue Feb 13, 2024 11:12 pm
by xray77
Ok, maybe I'll try to format the stick on the MAC to fat32 and maybe partition it to a 16GB partition and the rest to a second partition. I'll report back...
Posted: Wed Feb 14, 2024 12:17 am
by Mattk
FAT32 Yes, but would not create any Partitions
Posted: Wed Feb 14, 2024 11:03 am
by xray77
I have now completely deleted the stick once under Windows 11 Disk Management (partition) and created a new 16GB partition with Fat32 (only here is this offered under Win11).
I have left the rest of the stick unformatted and unorganized.
Now the backup works! So you can still have a partition on the stick...
Thanks for your help, have a nice day
regards, Michael
Re: Database Backup failed on RPI MeteoBridge **solved**
Posted: Fri Feb 16, 2024 10:21 pm
by Gyvate
under Windows FAT32 drives can only be formatted up to 32 GB.
However, in principle, up to 2 TB drives (partitions) can be formatted FAT32.
You need to use a different tool which allows FAT32 formatting for drives > 32 GB !
Then you can use the full capacity of a 64 GB USB device.
I use a 2 TB HDD formatted FAT32 for my MB backups.
Posted: Sat Feb 17, 2024 3:32 pm
Gyvate wrote: Fri Feb 16, 2024 10:21 pm
Thank you for this PRO hint! I didn't know that.
Posted: Sat Feb 17, 2024 6:30 pm
by Gyvate
admin wrote: Sat Feb 17, 2024 3:32 pm
you are welcome -
the only other potential restriction of FAT32 is that the size of a single file must not exceed 4GB.
If that's the case, i.e. the MB database grows bigger than 4 GB, the device needs to be formatted with ext4 and is no longer (directly) accessible under Windows.
However, in the exported METEOBRIDGE share they become visible also under Windows and can be managed (e.g. copied, deleted, ...)
