Cannot connect to port 22222 on pro 2. **solved**
Posted: Sun Apr 14, 2024 6:08 pm
Changing from Nano SD to pro 2 is almost complete,after some trouble with database and my historical data
With my Nano SD it is possible to connect a third party weather program through TCP IP and port 22222
I'm running CumulusMX on a Rpi and that works fine with my Nano SD, I use CumulusMX for my website and the Steelseries gauges
For testing I'm running CumulusMX on my laptop but it will not connect to my Pro2, also tried the Raspberry Pi to connect to the Pro 2 but it will not connect through port 22222
The only thing I changed was the IP adress in the CumulusMX program, which is of my Pro 2
Is it possible to connect with port 22222 on the pro 2 like the Nano SD?
Also logging states numerous times:
nbiot (14.04.2024 17:12:42): read error from device /dev/ttyS1: Bad file descriptor
Any help would be appreciated, because I really need Cumulusmx to work with my Pro 2
