Meteobridge RPI with Froggit HP1000SE PRO/Ecowitt. **solved**
Posted: Fri Apr 26, 2024 7:12 am
by Lexel
I have installed Meteobridge on my RPI4B. My Weatherstation is a HP1000SE PRO from Frogitt, but identical to Ecowitt HP2561.
For "Weatherstation" I selected "Ecowitt custom Upload". I entered my IP and the CGI path according to the description on the display (see pictures).
But now, I do not now what I should do next, that my Values will be submitted.
I get some Values, but I do not now, where this from.
Is there anybody with the same Station?
The only problem with the Meteobridge is that it doesn't want my SD card. But that probably has nothing to do with it.
Greetings from Rhineland-Palatinate
Alex
I'm normally no newbie, I have had before the Meteohub for about 5 years.
Re: Meteobridge RPI with Froggit HP1000SE PRO/Ecowitt
Posted: Fri Apr 26, 2024 8:53 am
by Lexel
I must answer myself.
After I installed the WS VIEW App on my Mobile Phone and made an Update of the Firmware it worked!!!!!
I'm sooooo happy now!!!!!
All Sensor now available!!!!
Greetings
Alex
Re: Meteobridge RPI with Froggit HP1000SE PRO/Ecowitt. **solved**
Posted: Fri Apr 26, 2024 12:51 pm
Happy that it works now and thanks for sharing the solution.
Posted: Fri Apr 26, 2024 3:37 pm
by Gyvate
@Lexel
you could also set the interval of the customized server post to 16 seconds if your outdoor array has the classic cup-type anemometer, or to 8 seconds if it's the ultrasonic anemometer ...
e.g. in the Weather34 Aurora dashboard you will see close-to-live data.
Monitor --> Weather Dashboard --> Launch Aurora Dashboard
(don't forget to tag "feed with live data")
