Tips & tricks for migrating data from Cumulus 1.9.4 to new NANOSD?
Posted: Thu May 30, 2024 3:40 pm
Well....... after many years of admiration I have invested in the NANOSD to move away from my tried and true MR3040 that seems to be on its last legs.
Since 2018 I have been logging all my MR3040 to original Weather34 template (MB-UB40-RRW) and the MqSQL backend, at the same time publishing to the newer Weather34 Template Aurora MKII 2024, and the original Cumulus 1.9.4 build 10992.
1. What is the best way to migrate from my MR3040 Meteobridge given all the settings that have been setup there to support the above?
2. What is the best way to migrate all my data from 2018 that is housed in my local data folder for the Cumulus 1.9.4 which seems to be the most thorough data set?
Curious what others have done successfully give my current setup. I did read through the data import option for Cumulus but it seems based on my files I will need to do some munipulation to a lot of data (example below from Nov18log.txt
Sample log file attached.
Thanks in advance for any pointers for those that have taken a similar path or have some suggestions.
29/11/18,22:40,49.3,92,47.1,0.0,0.0,0,0.00,0.00,29.674,3.28,66.9,59,0.0,49.3,49.3,0.0,0,0.000,0.000,48.6,0,0.0,0,0.00,3.28
29/11/18,22:41,49.3,92,47.1,0.0,0.0,0,0.00,0.00,29.674,3.28,66.9,59,0.0,49.3,49.3,0.0,0,0.000,0.000,48.6,0,0.0,0,0.00,3.28
29/11/18,22:42,49.2,92,47.0,0.0,0.0,0,0.00,0.00,29.676,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:43,49.2,92,47.0,0.0,0.0,0,0.00,0.00,29.676,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:44,49.2,92,47.0,0.0,0.0,0,0.00,0.00,29.673,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:45,49.2,92,47.0,0.0,1.0,274,0.00,0.00,29.674,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:46,49.2,92,47.0,0.0,1.0,274,0.00,0.00,29.674,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:47,49.2,92,47.0,0.0,1.0,274,0.00,0.00,29.675,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:48,49.2,92,47.0,0.0,1.0,274,0.00,0.00,29.676,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:49,49.2,92,47.0,0.0,1.0,262,0.00,0.00,29.676,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:50,49.2,92,47.0,0.0,1.0,262,0.00,0.00,29.675,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:51,49.2,92,47.0,0.0,1.0,262,0.00,0.00,29.675,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:52,49.2,92,47.0,0.0,1.0,262,0.00,0.00,29.678,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,22:53,49.2,92,47.0,0.0,1.0,258,0.00,0.00,29.678,3.28,66.9,59,0.0,49.2,49.2,0.0,0,0.000,0.000,48.5,0,0.0,0,0.00,3.28
29/11/18,23:30,49.5,92,47.3,1.0,1.0,270,0.00,0.00,29.680,3.28,66.7,59,1.0,49.5,49.5,0.0,0,0.000,0.000,48.3,0,0.0,270,0.00,0.00
30/11/18,00:00,49.3,92,47.1,4.0,4.0,225,0.00,0.00,29.683,3.28,66.6,59,4.0,48.0,49.3,0.0,0,0.000,0.000,46.4,0,0.0,225,0.00,0.00
30/11/18,00:30,49.0,91,46.5,3.0,3.0,23,0.00,0.00,29.682,3.28,66.5,59,3.0,48.5,49.0,0.0,0,0.000,0.000,46.5,0,0.0,22,0.00,0.00
30/11/18,01:00,49.0,91,46.5,5.0,5.0,23,0.00,0.00,29.676,3.28,66.4,59,5.0,47.0,49.0,0.0,0,0.000,0.000,45.4,0,0.0,22,0.00,0.00
30/11/18,01:30,49.0,91,46.5,0.0,0.0,0,0.00,0.00,29.693,3.28,66.2,59,0.0,49.0,49.0,0.0,0,0.000,0.000,48.2,0,0.0,0,0.00,0.00
30/11/18,02:00,48.8,91,46.3,2.0,2.0,68,0.00,0.00,29.695,3.28,66.1,59,2.0,48.8,48.8,0.0,0,0.000,0.000,46.8,0,0.0,67,0.00,0.00
30/11/18,02:30,48.8,91,46.3,1.0,1.0,45,0.00,0.00,29.698,3.28,66.0,60,1.0,48.8,48.8,0.0,0,0.000,0.000,47.4,0,0.0,45,0.00,0.00Thanks in advance for any pointers for those that have taken a similar path or have some suggestions.
