Weatherlink 6313 setup
Posted: Tue Aug 20, 2024 8:00 pm
by Wessel
I bought a Weatherlink 6313, but I didn't find a guide about how to setup Meteobridge to read data from Weatherlink Cloud. I already add the API V2 Key + Secret, but no sensor appears.
Re: Weatherlink 6313 setup
Posted: Tue Aug 20, 2024 10:46 pm
by Mattk
Not sure what you are expecting to do? 6313 is a console which reads from a Davis sensor suite and displays/uploads to WeatherLink.com
Meteobridge can receive data from the same Davis sensor suite and then can do various uploads including WeatherLink.com but only if it is a MBNano, not a MBPro etc
Not sure what you mean by setting up Meteobridge to read data from WeatherLink Cloud?
Posted: Wed Aug 21, 2024 1:57 pm
by Wessel
Mattk wrote: Tue Aug 20, 2024 10:46 pm
Meteobridge can't read data from Davis 6313, so I want to read data from Weatherlink Cloud, the only way to have my Meteobridge been feeded by my Davis.
Posted: Wed Aug 21, 2024 9:10 pm
by Mattk
Meteobridge needs to receive the data from the ISS same as the 6313 receives data from the ISS. Meteobridge can not receive data back from the WeatherLink Cloud and assume here you are referring to WeatherLink.com to whihc the 6313 would be uploading?
Posted: Wed Aug 21, 2024 9:21 pm
by Wessel
Mattk wrote: Wed Aug 21, 2024 9:10 pm
Exacly.
So, in my case, Meteobridge will be useless until be compatible with Weatherlink Live Console (6313). Won't be?
Posted: Thu Aug 22, 2024 4:56 am
by Mattk
So you have a Meteobridge and not a Meteobridge Pro then?
Posted: Thu Aug 22, 2024 9:50 am
by wvdkuil
Wessel wrote: Wed Aug 21, 2024 9:21 pm
Exacly.
You could use a meteostick (about 160$) as an add on to your meteobridge.
That way your could read the ISS data directly.
Adding weatherlink.com support to Meteobridge, would IMHO add another can of worms to the complexity of MB without adding a lot of extra users.
Also one needs a higher-priced upgrade to your weatherlink.com account to get the data more frequently.
That would easily offset the cost of a meteostick versus wl.com for the lifetime of the ISS.
Regards,
wim
Posted: Thu Aug 22, 2024 2:56 pm
by Wessel
Strange, I read at WXForum this message:
"Latest version of Meteobridge can read back data from the Davis cloud. This is worse than getting data directly from the Davis console, but is better than nothing. Obvious shortcomings are missing rapidly changing wind speed and direction events, which the Davis cloud does not provide."
Posted: Thu Aug 22, 2024 11:13 pm
by Mattk
Ok I see what you are referring now, I don't see this option but that might be because it's a MBPro and able to read sensor data direct? I will start another MBPro and see what I can see, have multiple stations uploading but a 6313 I don't have but that won;t matter as it's only reading data back.
My thoughts are you won't see sensors (as such) as all the MB is doing is reading archive data (@15 minutes on a basic plan) back from the cloud that has been uploaded from something like a 6313? The Cloud is a virtual station. Original release was Septemeber 18, 2023 release that noted is was a Beta implementation. I see further comments on October 7, 18, 2023 release, Feb 13, 2024
Posted: Wed Aug 28, 2024 12:32 am
by captgadget
I think is what you are referring to. If so this how you set it up.
Posted: Wed Aug 28, 2024 12:33 am
by captgadget
Sorry, I just checked and it's a console for you but probably a similar setup.
Posted: Wed Aug 28, 2024 8:08 am
by Mattk
captgadget wrote: Wed Aug 28, 2024 12:33 am
Quite a different setup, WLL and the 6313 Console are at the user location whereas the MB is reading already uploaded data back from WeatherLink.com (Davis WL Cloud)
@Wessel I have setup a MBPro with Davis WL Cloud and associated API V2 Key & Secret but what I see is some data which is obviously coming back but not all and that may be because I have multiple stations (AirLink, WLIP, MBNano etc) under the one WeatherLink account but the API applies to the account and not an individual station? There is only one AirLink station in this account and the MBPro is receiving AQ data and that can only be from WL Cloud? Just don't have a single station in an account to test the theory.
Do you have just the one (1) station in the account you are using the API from?
