Gaps in uploading to WU
Posted: Tue Aug 27, 2024 11:57 pm
by captgadget
I recently changed my internet service from Spectrum to Verizon Home Internet 5G. Then I had trouble with the fan in my Raspberry PI. So I powered down the Raspberry PI, fixed the fan, and powered it back up. I'm just giving background info here. The upload problem started showing up 4 days after the Verizon setup and 1or 2 days before I powered down the Raspberry PI. So does anyone have any clues as to why I am showing the gaps in the upload? I am now uploading through Davis and it's an absolute solid line.
Re: Gaps in uploading to WU
Posted: Thu Aug 29, 2024 5:01 pm
by captgadget
So I've done some experimenting. I had the number of retries set to 2, so I changed it to 5. The same gaps are showing up. So then I set the number of retries to 10, which seems to be working so far. If anyone else has any suggestions I'd be willing to try them.
Posted: Fri Aug 30, 2024 12:22 pm
When you are doing "rapid file" mode with WU (upload interval less than a minute) I recommend not to do any retries at all, as within a few seconds fresh data will be transferred anyway.
When there is an upload issue (WU server lame, routing problem, etc) and you fire uploads at a high frequency and you are doing retries your send queue in the Meteobridge will fill up and start blocking other operations.
Posted: Fri Aug 30, 2024 3:00 pm
by captgadget
Thanks for your suggestions which is my next move. So changing my retries didn't improve the problem. So I changed over to Davis to send the info and this morning when I checked the gaps showed up again once again pointing the problem that it is probably WU's problem. I'm heading over right now to try the new suggested settings.
Posted: Fri Aug 30, 2024 6:13 pm
you can see on "Monitoring - Upload Status" tab which uploads Meteobridge has done and status of those.
