Problems Meteobridge Rpi with Davis WLL
Posted: Fri Dec 06, 2024 10:42 am
I have a problem with meteobridge rpi and the new purchased Davis WLL. This will connect with the ISS from Davis Vantage Pro2 at the ch. 2 correctly and show the data correctly on the weatherklink basic account.
But when i will connect it to the meteobridge with the correct LAN IP only pick up the internal temperature and pressure. the external sensors will not found. But the wll chas this data so it shows correctly un weatherlink account.
What occurs here?
That's the log:
at sensors mapping see the following:
Can anywhere help me?
What occurs here?
That's the log:
logger (06.12.2024 09:04:08): databases connected. Update interval 3600 seconds.
logger (06.12.2024 09:04:08): data logger started.
logger (06.12.2024 09:04:08): connect station 0 (Davis WLL via SW Driver).
logger (06.12.2024 09:04:08): connect station 9 (System Data via Plug-in).
logger (06.12.2024 09:04:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.12.2024 09:04:08): services paused.data0!10num data10num CPU load
data0!11num data11num uptime
data0!12num data12num data storage usage
data0!13num data13num RAM usage
data0!15num data15num processes
data0!16num data16num data age
t0!9temp t9temp system temperature
thb0!0dew thb0dew indoor dew point
thb0!0hum thb0hum indoor humidity
thb0!0press thb0press pressure
thb0!0temp thb0temp indoor temperature
