After upgrade to version 6.1, the database runs out of space **solved**
Posted: Sat Jan 18, 2025 10:48 pm
by saalbers
I updated my Meteobridge Pro (red casing) to 6.1 (build 15486) today. After the upgrade the database has no more space and the internal storage is full:
Database size: 0 MB (0 MB free space available on media).
Before the upgrade no problems at all. After that only errors in the log:
dbase (18.01.2025 20:31:01): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active (1)
dbase (18.01.2025 20:31:01): cannot prepare select on update table 'data10num_hour' (after 0 tries in 1ms): no such table: data10num_hour
dbase (18.01.2025 20:31:01): rollback on insert forced (2) (hour): data10num
dbase (18.01.2025 20:31:01): cannot create table (after 0 tries in 1ms): database or disk is full (13)
dbase (18.01.2025 20:31:01): cannot commit (after 0 tries in 1ms): cannot commit - no transaction is active (1)
dbase (18.01.2025 20:31:02): cannot prepare select on update table 'data10num_hour' (after 0 tries in 1ms): no such table: data10num_hour
dbase (18.01.2025 20:31:02): rollback on insert forced (2) (hour): data10num
I also tried to build the DB on an external USB (front), but the USB is not recognized. I saw on this forum I am not the first one with this issue, so not sure this is a hardware problem. Perhaps the build size was to big for the free size left on the internal storage?
Re: After upgrade to version 6.1, the database runs out of space
Posted: Sun Jan 19, 2025 1:22 am
by Mattk
What version did you upgrade from?
What's the size and type of USB?
Posted: Sun Jan 19, 2025 3:15 pm
by saalbers
Not sure, one of the builds from September 2024.
Media Status
Size: 512.0K, 100% used, 0 available
Posted: Sun Jan 19, 2025 10:31 pm
by Mattk
My guess would be full or failed USB? If you log short intervals then could very well be a full USB?
FW 6.1 (Jan 14, 2025, build 15486) is fine in my MBPro (Red) with 1GB ATP and only 10% used. Database backup size is 32Mb
Posted: Tue Jan 21, 2025 5:07 pm
by robr57
Did you do a cold restart? I mean remove power and power on.
That made my internal disk available again.
Posted: Sat Jan 25, 2025 2:58 pm
Does the PRO red appear as "black" on the "System - Info" tab? If so, the internal USB hub chip may have died.
Posted: Fri Jan 31, 2025 9:11 pm
by saalbers
Yes, the PRO red appear as "black" on the "System - Info" tab.
Posted: Fri Jan 31, 2025 9:12 pm
by saalbers
Indeed the USB chip has died. Thanks to the excellent service of Boris, the problem is fixed. :D
Thanks, this issue can be closed.
