Tag not working on MBPro2. **solved**
Posted: Tue Feb 04, 2025 10:27 pm
by GeertLint
I am switching from a TPLinkbMeteobridge router (small white model) to a MBPRO2.
Migrating some FTP templates I see that the tag [th0temp-havg.1:--]°C gives —°C on the MBPro2 although it works fine on my old Meteobridge . I also tried [th0temp-avg60.1:--]°C, but with the same result. I have the idea that this is only with the th0temp sensor.
Anyone a suggestion or is this a bug on MBPRO2?
Re: Tag not working on MBPro2
Posted: Tue Feb 04, 2025 10:40 pm
by Mattk
Don't see any issues with those sensor-selector combinations on a MBPro. Going to start a Pro2 and see what I get?
Posted: Tue Feb 04, 2025 11:41 pm
by Mattk
Nothing wrong with the actual context in a Pro2 either. You might need to look a little wider with the implementation and/or FTP?
Posted: Wed Feb 05, 2025 12:25 am
by GeertLint
Thanks for checking! I will look into it this next weekend and hope to find the problem. I will give an update here.
Posted: Wed Feb 05, 2025 1:10 am
by Mattk
Also uploaded via a simple FTP (was previously using email) with your parameters from a Pro & Pro2, no issues noted.
Posted: Mon Feb 10, 2025 8:46 pm
by GeertLint
Thanks for checking, I found that there was an error in the html code on the template page. After deleting the code in the cell of the table and retyping it, it works again
Posted: Mon Feb 10, 2025 10:29 pm
by Mattk
Another thing to be aware of is the Selected Event Type used as for example havg is the "average for this hour" but exactly on the hour there essentially is no hour, hence will be blanked out where as "before every full hour" will give the result for the immediate past hour
