Meteobridge VM and Ecowitt Custom Upload. **solved**
Posted: Thu May 29, 2025 7:40 pm
by kd7eir
I'm running Meteobridge VM and having problems feeding it with Ecowitt Custom Upload. These are my settings, as provided by Meteobridge, using the Ecowitt protocol type:
IP/Server: 192.168.12.140
Connection: Path:/public/ecowitt0.cgi
Port: 80
No data is uploaded to Meteobridge. If I choose the GW3000, the data uploads.
Any suggestions?
(Edited to remove angry ranting)
Re: Meteobridge VM and Ecowitt Custom Upload
Posted: Thu May 29, 2025 10:00 pm
Not sure what is with your Meteobridge VM install, mine shows the ecowittX.cgi entries in /www/public folder.
root@MBX86:~# ls -la /www/public/
lrwxrwxrwx 1 root root 34 Jun 18 2024 ecowitt0.cgi -> ../../home/meteobridge/ecowitt.cgi
lrwxrwxrwx 1 root root 34 Jun 18 2024 ecowitt1.cgi -> ../../home/meteobridge/ecowitt.cgi
lrwxrwxrwx 1 root root 34 Jun 18 2024 ecowitt2.cgi -> ../../home/meteobridge/ecowitt.cgi
lrwxrwxrwx 1 root root 34 Jun 18 2024 ecowitt3.cgi -> ../../home/meteobridge/ecowitt.cgi
lrwxrwxrwx 1 root root 34 Jun 18 2024 ecowitt4.cgi -> ../../home/meteobridge/ecowitt.cgi
lrwxrwxrwx 1 root root 34 Jun 18 2024 ecowitt5.cgi -> ../../home/meteobridge/ecowitt.cgi
Why do you think there is no "ecowitt0.cgi" in your /www/public folder? Did you check file system via ssh login?
Posted: Thu May 29, 2025 10:18 pm
by kd7eir
I just looked in /public, not www/public—my mistake.
Either way, pointing to 192.168.12.140:80/public/ecowitt0.cgi returns a 404 error.
I created a second station that points to 192.168.12.140:80/public/ecowitt1.cgi and also returns a 404 error.
Posted: Thu May 29, 2025 10:33 pm
Please try with just released update. I saw that there is a bug on PRO2 and VM.
However, using custom uploads is an edge case (at least that is my excuse). When you have one one of the GWxxxx devices, please, please load data from there. It is much better. Custom uploads is just meant for users that don't have a GWxxxx device.
Posted: Thu May 29, 2025 10:49 pm
by kd7eir
Updating now.
And I understand why to use the GW3000 upload.
Sorry for my confused rantings.
Posted: Thu May 29, 2025 10:56 pm
by kd7eir
admin wrote: Thu May 29, 2025 10:33 pm
The update resolved the issue. Thank you!
