Meteobridge Nano SD. **solved**
Posted: Tue Nov 04, 2025 2:09 pm
by saroyan17
I just changed phone carriers and I can't log into the Meteobridge Nano to replace the new WiFi codes.
Thank you for your help.
Re: Meteobridge Nano SD
Posted: Tue Nov 04, 2025 3:20 pm
by wvdkuil
saroyan17 wrote: Tue Nov 04, 2025 2:09 pm Hello,
It works the other way around. If the nano can not find your WiFi it provides a Wifi network for you to connect into with your tablet or computer.
Then you can select the new WiFi network to be used by the Nono in the drop-down of found networks.
https://www.meteobridge.com/wiki/index. ... ridge_NANO
Connectivity
Initial setup is done by connecting with a mobile device to the WiFi that the NANO itself does provide.
Succes,
Posted: Tue Nov 04, 2025 4:39 pm
by saroyan17
I'm not an expert, but I can find a meteobridge-B8D81266c6d5 on the Wi-Fi network.
What password does it require? The Wi-Fi password, which it doesn't seem to accept, or the “meteobridge” password, which it does accept?
Thank you very much.
JJP
Posted: Tue Nov 04, 2025 5:43 pm
by wvdkuil
saroyan17 wrote: Tue Nov 04, 2025 4:39 pm Hello,
JJP
You always use your meteobridge password to login to your Meteobridge. Either on your normal in-house WiFi or now on the temporary MB-Wifi accesspoinr only.
Then you can set your new providers new Wifi codes in the Network tab.
Restart after you set the new wifi name (use the dropdown) and new-wifi password.
Succes,
Posted: Thu Nov 06, 2025 9:07 pm
by saroyan17
Thank you, the problem has been resolved.
Thank you,
JJP
