Ambient Weather Weatherbridge SFTP Problem
Posted: Wed Oct 14, 2026 12:15 am
by reifheck
Hi.
Not sure if this is right place for this.
I'm using the Ambient Weather Weatherbridge (Meteobridge) to SFTP a file to my web server.
The firmware is updated to Meteobridge 6.4 (Sep 19 2026, build 15721), FW 1.4
When I tried to test uploads with Meteobridge using SFTP, I got the following errors:
Error: SFTP test upload failed: Couldn't read packet: Connection reset by peer
Error: Proxy-SFTP test upload failed: Error: SFTP connect to aurora.anaxanet.com via port 22 failed.
I looked at the logs in Meteobridge and didn't see any errors.
The Web Host sent me the following log of this error on their server.
Hello Reif,
So, my theory about the old, outdated client and TLS/cipher suite issue appears to be correct.
[2026-10-13 20:13:10]:CONNECT [108132] - [71.218.28.0]: - Incoming connection request on SSH SFTP listener 2 at 10.8.245.100:22 accepted from 71.218.28.0:38873
[2026-10-13 20:13:10]: INFO [108132] - [71.218.28.0]: - Client Identification: SSH-2.0-dropbear_2011.54
[2026-10-13 20:13:10]: ERROR [108132] - [71.218.28.0]: - No common KEX: [S: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,curve25519-sha256,curve25519-sha256@libssh.org,curve448-sha512,curve448-sha512@libssh.org,diffie-hellman-group18-sha512,diffie-hellman-group16-sha512,diffie-hellman-group14-sha256,kex-strict-s-v00@openssh.com] [C: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1]
[2026-10-13 20:13:10]: ERROR [108132] - [71.218.28.0]: - Key exchange failed: Could not agree on key exchange parameters
[2026-10-13 20:13:10]:CONNECT [108132] - [71.218.28.0]: - Closing connection. Reason code : 3
[2026-10-13 20:13:10]:CONNECT [108132] - [71.218.28.0]: - Connection terminated
It is running dropbear, an SFTP implementation that is extremely hold (back in like 2010-2011 old). This is the cause, an outdated SFTP client.
Our server is requesting...
ecdh-sha2-nistp256
ecdh-sha2-nistp384
ecdh-sha2-nistp521
curve25519-sha256
curve448-sha512
One of these ciphers, but your client is saying "Great... I can do..."
They cannot agree, so the connection gets dropped. These 2 ciphers are extremely weak, group1 is from the early 2000s and group14-sha1 is from around 2007 era. The only fix here, is a newer SFTP client with modern cipher support.
They then created a work around and don't know how long the fix will work
It started working and they sent me the log with the fix:
Hello Reif,
[2026-10-13 21:12:12]:CONNECT [108283] - [71.218.28.0]: - Incoming connection request on SSH SFTP listener 2 at 10.8.245.100:22 accepted from 71.218.28.0:47611
[2026-10-13 21:12:12]: INFO [108283] - [71.218.28.0]: - Client Identification: SSH-2.0-dropbear_2011.54
[2026-10-13 21:12:12]:CONNECT [108283] - [71.218.28.0]: - Agreed upon KEX: 'diffie-hellman-group14-sha1' Host Key: 'ssh-rsa' C2S : 'aes128-ctr, hmac-sha1, none' S2C : 'aes128-ctr, hmac-sha1, none'
[2026-10-13 21:12:13]: INFO [108283] - [71.218.28.0]: - DH Key sizes: Server Public '2048', Client Public '2048'
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]: - Authenticating password for user 'uqkytoll_reifheck'
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]: - Native user 'uqkytoll_reifheck' authenticated
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]:uqkytoll_reifheck - Channel Open: 'session', Sender Channel: 0, Local Channel: 182144, Init Window Size: 24576, Max Packet Size: 32768
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]:uqkytoll_reifheck - Channel Request for 'subsystem : sftp', Sender Channel: 0, Local Channel: 182144, Reply: false
[2026-10-13 21:12:14]:COMMAND [108283] - [71.218.28.0]:uqkytoll_reifheck - Client SFTP version: 3
[2026-10-13 21:12:14]:COMMAND [108283] - [71.218.28.0]:uqkytoll_reifheck - Real Path for '.'
[2026-10-13 21:12:14]:COMMAND [108283] - [71.218.28.0]:uqkytoll_reifheck - Stat: /MBtags.php
[2026-10-13 21:12:14]:COMMAND [108283] - [71.218.28.0]:uqkytoll_reifheck - File open command received for '/MBtags.php' requesting WRITE,CREATE,TRUNC
[2026-10-13 21:12:14]: SYSTEM [108283] - [71.218.28.0]:uqkytoll_reifheck - File handle to '/MBtags.php' opened
[2026-10-13 21:12:14]: SYSTEM [108283] - [71.218.28.0]:uqkytoll_reifheck - Upload started for file 'C:\HostingSpaces\uqkytoll\westdenverweather.com\wwwroot\MBtags.php'
[2026-10-13 21:12:14]: SYSTEM [108283] - [71.218.28.0]:uqkytoll_reifheck - Successfully stored file at 'C:\HostingSpaces\uqkytoll\westdenverweather.com\wwwroot\MBtags.php' (46278 B received)
[2026-10-13 21:12:14]: SYSTEM [108283] - [71.218.28.0]:uqkytoll_reifheck - Handle '/MBtags.php' closed
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]:uqkytoll_reifheck - Received EOF for channel 182144, responding with EOF and close to sender channel 0
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]:uqkytoll_reifheck - Channel '182144' removed
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]:uqkytoll_reifheck - The client closed the connection
[2026-10-13 21:12:14]:CONNECT [108283] - [71.218.28.0]:uqkytoll_reifheck - Connection terminated
It did work, agreed on KEX diffie-hellman-group14-sha1, I cannot say this will last forever... because it is an older KEX and we try and balance newer modern ciphers with older ones, but not 20-year-old ones like diffie-hellman-group14-sha1. I would highly recommend getting with the developers of this and seeing if they can update the SFTP client to a modern version. Dropbear is still very actively developed, latest version is 2026.94 from July of this year. It does not have to be the very latest, 2013.62 supports curve25519-sha256@libssh.org, which we do support. So even a minor bump would help.
I also used Proxy-SFTP and it worked this time.
The Web Host sent me this log as well:
Hello Reif,
[2026-10-13 22:38:41]:CONNECT [108491] - [71.218.28.0]: - Incoming connection request on SSH SFTP listener 2 at 10.8.245.100:22 accepted from 71.218.28.0:48765
[2026-10-13 22:38:41]: INFO [108491] - [71.218.28.0]: - Client Identification: SSH-2.0-dropbear_2011.54
[2026-10-13 22:38:41]:CONNECT [108491] - [71.218.28.0]: - Agreed upon KEX: 'diffie-hellman-group14-sha1' Host Key: 'ssh-rsa' C2S : 'aes128-ctr, hmac-sha1, none' S2C : 'aes128-ctr, hmac-sha1, none'
[2026-10-13 22:38:43]: INFO [108491] - [71.218.28.0]: - DH Key sizes: Server Public '2048', Client Public '2048'
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]: - Authenticating password for user 'uqkytoll_reifheck'
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]: - Native user 'uqkytoll_reifheck' authenticated
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]:uqkytoll_reifheck - Channel Open: 'session', Sender Channel: 0, Local Channel: 182480, Init Window Size: 24576, Max Packet Size: 32768
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]:uqkytoll_reifheck - Channel Request for 'subsystem : sftp', Sender Channel: 0, Local Channel: 182480, Reply: false
[2026-10-13 22:38:44]:COMMAND [108491] - [71.218.28.0]:uqkytoll_reifheck - Client SFTP version: 3
[2026-10-13 22:38:44]:COMMAND [108491] - [71.218.28.0]:uqkytoll_reifheck - Real Path for '.'
[2026-10-13 22:38:44]:COMMAND [108491] - [71.218.28.0]:uqkytoll_reifheck - Stat: /MBtags.php
[2026-10-13 22:38:44]:COMMAND [108491] - [71.218.28.0]:uqkytoll_reifheck - File open command received for '/MBtags.php' requesting WRITE,CREATE,TRUNC
[2026-10-13 22:38:44]: SYSTEM [108491] - [71.218.28.0]:uqkytoll_reifheck - File handle to '/MBtags.php' opened
[2026-10-13 22:38:44]: SYSTEM [108491] - [71.218.28.0]:uqkytoll_reifheck - Upload started for file 'C:\HostingSpaces\uqkytoll\westdenverweather.com\wwwroot\MBtags.php'
[2026-10-13 22:38:44]: SYSTEM [108491] - [71.218.28.0]:uqkytoll_reifheck - Successfully stored file at 'C:\HostingSpaces\uqkytoll\westdenverweather.com\wwwroot\MBtags.php' (46300 B received)
[2026-10-13 22:38:44]: SYSTEM [108491] - [71.218.28.0]:uqkytoll_reifheck - Handle '/MBtags.php' closed
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]:uqkytoll_reifheck - Received EOF for channel 182480, responding with EOF and close to sender channel 0
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]:uqkytoll_reifheck - Channel '182480' removed
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]:uqkytoll_reifheck - The client closed the connection
[2026-10-13 22:38:44]:CONNECT [108491] - [71.218.28.0]:uqkytoll_reifheck - Connection terminated
Still using the older diffie-hellman-group14-sha1 KEX as well, so it would need to be modernized as well.
Is there anything the developer can do to fix this?
Thank you,
Reif Heck
