Another License issue ** solved **
Posted: Thu Feb 07, 2008 3:59 am
by DrMarcus
I recently received a wmr-100 as a Christmas present and after setting it up didn't want to leave my PC on all night, so ordered the meteohub from Ambient Weather in Phoenix, Arizona.
After the initial setup, the system had an activation code already listed and I continued to set everything up. However, as of the last reboot, the system is now saying I have a \"Limited Demo Version, 9 days left\". I was under the impression I had purchased a license with the hardware.
Also, on a slightly different note; the wan IP lists as \"WAN IP: no internet access\". Is this because of the limited functionality or is something else wrong?
Re:Another License issue
Posted: Fri Feb 08, 2008 1:30 am
by DrMarcus
As an update, I worked with Ambient Weather, and was able to resolve the activation problem. But the Wan IP still says 'no internet access'.
I've tried changing IP's. Changing from dynamic to static. Placing the ip in the DMZ... All with no results.
I even updated to v 1.8d.
Any suggestions?
Posted: Fri Feb 08, 2008 1:51 am
by DrMarcus
Not at all sure what setting I changed... but after about 3 hours of fiddeling with everything I finally got a wan IP address...
Looks like everything is working!!!
Keeping the fingers crossed...
Posted: Fri Feb 08, 2008 8:25 pm
welcome to the board. Sorry, that you had a hard start.
To have an idea for future users... did you change something with Meteohub that solved the WAN-IP issue or was it with your router setup?
