4.1 Barometer settings
Posted: Tue Feb 17, 2009 4:55 am
I noticed the new settings available for the Barometer when I upgraded from 3.3 to 4.1. I first started with Elevation and Temperature calc but found that to be substantially off the mark when calibrated with other local stations and the NWS stations in the area. I switched back to elevation only and that brought it right back in line with other stations in the area and my older readings prior to updating....
Just a comment to share with everyone as I thought the Temp/elevation calcs would be more accurate but not in this case.....plus I'm in Colorado and mile above sea level...
Gregg
Gregg
