Add compatibility with 1-wire sensors
Posted: Fri Mar 06, 2009 6:13 pm
by tparvais
Hello
It would be very nice to add 1-wire compatiblity on Meteohub.
More and more weather sensors are available and are very easy to implement on field.
Cfr.
http://www.aag.com.mx/aagusa/index1.html
libraries and tools already exist for Linux (OWW, OWFS...)
This is what I'm waiting before mobing to Meteohub
Thank you
Re:Add compatibility with 1-wire sensors
Posted: Sat Mar 07, 2009 11:32 am
by skyewright
tparvais wrote:It would be very nice to add 1-wire compatiblity on Meteohub.
1-wire is very different to the "off-the-shelf" systems. With most systems the range of possible sensors is closely defined. With 1-wire an enourmous range of things are possible, so a truely generic 1-wire interface could be quite an undertaking!
However, Meteohub v4's "plug-in" option
already makes many things possible....
I have a very basic 1-wire plug-in running already. Using OWFS to talk to the 1-wire system some c++ based code reads values from some 1-wire sensors and writes an equivalent Meteohub style sensor record to stdout, which Meteohub happily reads and incorporates into its data base.
I'm reading a temp, an humidity and pressure and writing those as a thb sensor. The same principle would be fine for other sensors and I'm slowly working on it, but this it has to be very much a spare time project for me.
At this stage the plug-in is still very basic and wouldn't be much use to anyone else unless they were happy editing and compilng c++ code to configure it for their own sensor ids.
Maybe at some stage something more generic and more readily configurable will appear - either from me or from someone else - that's the beauty of the "plug-in" interface, i.e. anyone (with relevant coding ability) can add additional data sources to Meteohub. :)
Posted: Sun Mar 08, 2009 7:27 am
by dudelsack
skyewright, hope you will find the time to come out with a version for a 1-wire plugin you can share with all the non-coders among us.
Would love to get some of my 1-wire sensors online in meteohub.
Matt
Posted: Tue Mar 10, 2009 5:32 pm
by sprockett
I have the AAG one wire weather station.
I have found he build quality a lot better (more solid) than most.
It would be very nice to see wind speed, direction, temp humidity and possibly rain incorporated into metro hub.
I have tried "OWW" but as a non programmer with nill Linix knowledge i always get lost very quickley.
The thing i like about Meteo Hub is the intuitive GUI, if Meteo Hub had a plug in or something to take the AAG 1-wire weather station I am sure it would be very attractive option for the 1-wire comunity.
Posted: Tue Mar 10, 2009 6:52 pm
by skyewright
sprockett wrote:if Meteo Hub had a plug in or something to take the AAG 1-wire weather station I am sure it would be very attractive option for the 1-wire comunity.
Even providing for that is not quite as straight forward and "standard" as it might appear, since AAG have just come out with a new model 1-wire weather station that uses different 1-wire chips and is thus quite different from a software point of view (though still 1-wire, of course).
There is a saying in Scottish Gaelic, "He who lives long will see many things".
I hope we all get to see lots. ;) :)
Re: Add compatibility with 1-wire sensors
Posted: Tue Dec 07, 2010 11:04 pm
by tparvais
The ideal world is to use Midon TEMP08 as 1-wire gateway.
And use meteohub as frontend/logger/portal
TEMP08 has RS232 interface and very simple commands
Maybe to be investiguated ?
Posted: Wed Dec 08, 2010 4:20 pm
by rune
Another options would be to integrate Meteohub & the Swedish guy Per Malmberg's brilliant MSure application (
www.msure.se). I'm currently exporting sensor data from Meteohub to MSure, but maybe the other way could also be acomplished? And perhaps on a "lower-level".
MSure can do much much more with 1-Wire than just reading temperature sensors, so it's a good addition to Meteohub.
Depending on setup, the disadvantage could be that MSure is Windows based and Meteohub could be running on something else...
Posted: Wed Dec 08, 2010 5:16 pm
by tparvais
rune wrote:Another options would be to integrate Meteohub & the Swedish guy Per Malmberg's brilliant MSure application (
http://www.msure.se). I'm currently exporting sensor data from Meteohub to MSure, but maybe the other way could also be acomplished? And perhaps on a "lower-level".
how can we import others data to meteohub ?
Are they available exaclty as sensor data captured directly by Meteohub ?
Tx
Posted: Thu Sep 15, 2011 3:56 pm
by tparvais
up
Posted: Tue Oct 04, 2011 8:18 am
by rune
MSure (or now BeyondMeasure) uses SQLlite or MySQL so all data is available for other systems. It can also read the textfiles from e.g. Metehub and use that data.
