Upgrade from 3.3c to 4.1f
Posted: Mon Mar 09, 2009 7:58 pm
by binbags
Hi
Have just done upgrade to the latest 4.1f. I have assigned weather station RFxcom/usb. I am now trying to install the sensors, for some reason that I have not yet fathomed out,:ohmy: it is not seeing the wind sensor. The Wmr698 is still reading all sensors OK.
The other small point is that when I go to save the data in the "select sensor window" it comes back with the answer that "this sensors has the same name more than once"
Re:Upgrade from 3.3c to 4.1f
Posted: Mon Mar 09, 2009 8:45 pm
by sevenless
I can't speak for the first problem, but I had this same problem when I upgraded from version 3 to 4. On the sensors page, you first need to clear all the sensor IDs/names at the bottom of the page in the "Additional IDs to be evaluated" section (these aren't associated with any station, but still have names and sensor IDs -- presumably as part of the new feature to enable logging additional external data.)
Once you clear those, then you can re-assign them to the actual weather station and give them the same names you were previously using.
Posted: Mon Mar 09, 2009 9:21 pm
by binbags
Once you clear those, then you can re-assign them to the actual weather station and give them the same names you were previously using.[/quote]
Hi
Thanks for the info, I will try once meteohub has finished it's re-compute data.
Posted: Tue Mar 10, 2009 9:30 am
by binbags
sevenless
Thanks for that, all is well:cheer: . I will have to re-assign the newly named sensors to the graphs or at least a few of them.
