Alix.1D can´t enter WLAN IP - no connection to Fritz.Box **
Posted: Mon Mar 09, 2009 10:43 pm
by markison
i´m using the meteohub with an alix.1d and a wlan-modul. on the lan everything works fine.
when i chance to the wlan i can enter the ssid and the WPA-password. but when i try to enter the static wlan-IP it is empty after i save. i also tried the wlan-dhcp. but when i reboot the alix, gives me every time the static LAN-IP. Image
Re:Alix.1D can´t enter WLAN IP - no connection to Fritz.Box
Posted: Sun Apr 12, 2009 10:10 am
by markison
Problem solved, i used a wrong wlan module
comment:
Problem ist, dass der WLAN-Adapter kein AR5005 ist, sondern ein AR5006X, der von Meteohub nicht unterstützt wird.
PCI-ID muss 168c:001a sein (nicht 168c:001b). Kleiner Unterschied, leider mit grosser Wirkung.
