Meteohub Update 4.2rc4
Posted: Sat Mar 21, 2009 1:37 pm
Improves stability of data logging by adjusting job priorities and slightly changing behavior when a station drops off.
Re:Meteohub Update 4.2rc4
Posted: Sat Mar 21, 2009 11:50 pm
by rovinj
Upgrading from Version 4.1f to this version caused no data logging on my WMR-928 station.
Posted: Sun Mar 22, 2009 12:16 am
As the update does not change any wmr928 specific code parts this is quite a surprise.
What version of Meteohub did you use before? If updated a 3.x version, you have to setup settings on pages "weather station" and "sensors" from scratch, as these parts have completely changed in 4.x to allow multiple weather stations.
What does "meteohub log" say?
Posted: Sun Mar 22, 2009 12:23 am
by rovinj
I regulary update version 4.1 (NSLU). Now I'm on 4.1f. After you release 4.1g, I updated and sensors stoped to get data. So I go back to 4.1f. Today I tried to update to 4.2rc4 and again get same problems.
Update:
I tried one again to upgrade to 4.2rc4. When upgraded, on main screen get following error:
Get the error: Error file open: /var/run/loggerd.pid: No such file or directory
On Sensors menu:
Warning: Data logging has been halted.
Then on Maintenance I restared logging and data was started to log. Tried also to restart NSLU and get again the error about loggerd.pid.
Posted: Sun Mar 22, 2009 2:43 am
by samikki
Same thing here. I get the error about loggerd.pid when starting this version. Re-setting weather station starts logging.
At first I thought it was because of defective memory stick but I have now done fresh install on a new stick + cleaned up broken data files.
I have also suffered from sensors dropping off for 45 minutes - hour. I still have to confirm that it wasn't related to bad memory stick. This night I'm running on healthy system, in the morning I'll see if the sensors are still dropping.
Running WMR-100 with NSLU2.
Sami
Posted: Sun Mar 22, 2009 8:20 am
by rovinj
Samikki, if you try to reboot NSLU error loggerid.pid will return.
Posted: Sun Mar 22, 2009 9:58 am
by Rikken
Same Problem here. NSLU / WMRS 200. After updating to 4.2rc4 Data logging stops after rebooting NSLU.
Posted: Sun Mar 22, 2009 10:14 am
sorry, rc4 had a nasty bug when starting data logging. Just released rc5 has this solved.
Posted: Sun Mar 22, 2009 11:08 am
by Rikken
Ja, jetzt läufts wieder! Thanks!!! :)
Posted: Sun Mar 22, 2009 3:26 pm
by samikki
Just to note: haven't had sensor dropoff last night after fixing faulty raw data.
But I can confirm the loggerd error when booting up.
