No Web Interface, but can access using SSH?
Posted: Mon Jul 06, 2009 1:46 am
by Johnson
Just starting with Meteohub and successfully flashed the NSLU2 to v2.3. Have created a 2GB USB drive using DD for Windows and inserted in Drive 2 USB. Reboot and I can't access the Web interface but I can access NSLU2 via SSH and login as Root. Any ideas on why Web interface is not coming up? As no Linux guru, where can I look for log files to find errors for services starting? many thanks Shane
Re:No Web Interface, but can access using SSH?
Posted: Tue Jul 14, 2009 6:16 am
by Johnson
Solved it. It was the creation of the Linux format USB stick in that I was selecting the Windows drive name and not the physical name of the USB stick. Thus the Disk Image write was placing a Win95 format partition on the USB and not a ext3 type partition. Thus I was logging on via SSH to the initial OS and not the one which boots off the USB and also provides the Web interface.
A good learning exercise, as I now know a lot more around how this SLUG systems work and what other apps etc can be run on SLUGs or equivalent units. No to purchase my weather station and get things working !
