WMR100 extra sensor/meteohub.weather display
Posted: Thu Jul 09, 2009 12:23 pm
by evan.mac
I have bought an extra temperture sensor for my wmr100. It's working as far as seeing it on the console and in meteohub. I can also see it in weather underground. My only problem is I can't see it in weather display on my computer. I have meteohub setup to send the extra temperture reading to weather display but weather display still shows the temperture from the main temperture/wind sensor.
Anyone have any ideas?
Re:WMR100 extra sensor/meteohub.weather display
Posted: Thu Jul 09, 2009 2:52 pm
by skyewright
evan.mac wrote:Anyone have any ideas?
What id have you assigned to the sensor in Meteohub, e.g. th2?
Posted: Thu Jul 09, 2009 5:22 pm
by evan.mac
I assigned an id of th1.
Thanks skyewright
Posted: Thu Jul 09, 2009 6:37 pm
by skyewright
evan.mac wrote:I assigned an id of th1.
On my setup th1 appears in WD as extra sensor 1.
As it's July 2009, the values should be appearing in columns temp1 & hum1 in
\\wdisplay\\logfiles\\ 72009extralog.csv
Does that help?
David
Posted: Fri Jul 10, 2009 12:17 am
by evan.mac
I should of made myself clearer. I'm trying to get the readings from the th1 sensor to display in the weather display main window. I don't see any settings within WD that lets me select the th1 sensor but within meteohub I can set th1 as the main sensor for sending data to WD.
Thanks for your help.
Evan
Posted: Fri Jul 10, 2009 10:52 am
by skyewright
evan.mac wrote:I don't see any settings within WD that lets me select the th1 sensor but within meteohub I can set th1 as the main sensor for sending data to WD.
Darn! I wrote a long reply, but Joomla had logged me off and threw it away! :(
It's so long since I had that happen I'd got out of the habit of "copy before Submit", so here's the short version.
I think you are using the "logging protocol" to communicate between WD and Meteohub, but are trying to "change" the main sensor via the Meteohub "WD Export" page? If so, that's not going to work.
The "WD Export" page is nothing to do with the "logging protocol".
With the "logging protocol" WD uses whatever it receives as th0 as the main temp/hum, so the simple solution is to reassign your sensors in Meteohub.
There is an elaborate alternative involving a custom 'proxy' meteolog.cgi running on a separate server. An outline of that alternative was the main difference between this sort answer and the the longer one I wrote earlier. If you want the details, please ask but reassigning the sensors in Meteohub is far simpler and is what imagine most people would opt for.
Does that make sense?
David
Posted: Fri Jul 10, 2009 11:48 am
by evan.mac
Yes it does make sense and it worked.
Thanks so much skyewright
