Error when flashing SheevaPlug
Posted: Tue Aug 04, 2009 4:27 pm
When i try to use command: ./meteoflash.sh mac 00:50:??:??:??:?? i receive an error. (mac address is censurated)
This is what i receive:
Or mabe it has somethin to do with the FTDI chip: http://www.ftdichip.com/Drivers/VCP/Lin ... sio.tar.gz
Do i have to install LinuxHost files that come with the SheevaPlug?
LinuxHost\\Linux Host Filesystem - rootfs.tar.bz2
LinuxHost\\gcc.tar.bz2
Any suggestions?
Mabe the OS does not recognise my USB chip or SheevaPlug?root@ubuntu:/home/meteoplug-installer# ./meteoflash.sh mac 00:50:??:??:??:??
openocd logs can be inspected at /var/log/sheeva.log
mac used: 00:50:??:??:??:??
erase uboot environment... done
set u-boot default environment variables... done
set u-boot custom environment variables... done
set u-boot MAC... done
burn u-boot including environment...
Error: flashing u-boot environment via openocd failed
ERRORLOG:
Open On-Chip Debugger 0.2.0-in-development (2009-05-17-10:32) svn:1800M
BUGS? Read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
$URL: http://svn.berlios.de/svnroot/repos/ope ... /openocd.c $
2000 kHz
dcc downloads are enabled
Error: unable to open ftdi device: device not found
Runtime error, file "command.c", line 453:
Any suggestions?
