Wunderground wind gust with RainWise MkIII
Posted: Thu Aug 27, 2009 1:48 am
by tsmedley
I am using Meteohub 4.4 to process data from a RainWise MkIII using the MkIIICC computer interface.
I have observed two problems with wind reporting:
1) The Wind Gust reading is never reset. I believe the RainWise interface requires a "W" command to reset the Wind Gust. Meteohub apparently does not send this command.
This affects all Meteohub data streams - dashboard, WD Live, wunderground, CWOP.
2) Wind values uploaded to Wunderground show the wind gust value reported for the avereage wind speed. This is unique to Wunderground - average wind values are reported correctly to CWOP, or on the dashboard or WD Live.
If you look at my PWS 'KWAHOQUI3' on wunderground.com you can easily see what is happening. The wind gust value never changes, and the average wind is reported to be the same as the wind gust.
All other sensors on the MkIII appear to be reported correctly.
I can provide data samples from the RainWise MkIII and the MkIII computer interface documentation if that is helpful.
Terry
Re:Wunderground wind gust with RainWise MkIII
Posted: Fri Aug 28, 2009 3:22 am
by tsmedley
Here is further documentation of wind/wind gust problem with Meteohub and RainWise MkIII.
This is an image of the data received by Weather Underground from Meteohub. It shows two problems: 1) the average wind and wind gust are the same and 2) the wind gust is never reset.
This text snippet shows that the data received by CWOP from Meteohub correctly distinguishes between average wind and wind gust:
[file name=Meteohub_CWOP.txt size=11571]http://www.meteohub.de/joomla/images/fb ... b_CWOP.txt[/file]
I will separately post addition graphs with further examples of the incorrect wind reporting.
Terry
Posted: Fri Aug 28, 2009 3:26 am
by tsmedley
This chart shows data received by Weather Underground from Meteohub AND WeatherView software. The times for each software are labeled on the graph. From 10A to 2PM, WeatherView software was being used, and the average wind and wind gust is reported correctly, and the wind gust value is reset as expected. At 2PM, I switched back to Meteohub and you can see the average wind and wind gust is reported to be the same, and the wind gust is never reset. At 7PM I manually reset the wind gust (by sending a ':W' command to the interface).
Posted: Fri Aug 28, 2009 3:53 am
by tsmedley
My last example is a graph produced by Meteohub showing correct reporting of wind average and wind gust values, during the same period of time as my previous example showing incorrect reporting of the same information to Weather Underground:
I have switched back to using WeatherView until the wind gust reset and reporting problem can be resolved. If you should happen to examine my PWS 'KWAHOQUI3' on Weather Underground, you will see the Meteohub problem only on 26 and 27 August.
Terry
Posted: Wed Jan 06, 2010 9:59 pm
by vlywst
Having the identical problem.:S Anyone have any suggestions?
Posted: Thu Jan 07, 2010 5:20 pm
by tsmedley
Boris fixed this right after my post, several versions ago. I'm currently running v4.5i, and wind reporting from the RainWise MkIII is fine. What version is your Meteohub?
Posted: Thu Jan 07, 2010 7:09 pm
by vlywst
Just upgraded to 4.6 and have also been working with Boris. Will advise results
Posted: Fri Jan 08, 2010 5:20 pm
by vlywst
Upgraded to 4.6 and all is well:)
Re: Wunderground wind gust with RainWise MkIII
Posted: Fri Dec 28, 2012 5:35 am
by thlmobile
As far as I could see just logview protocol is documented, not the protocol of data which flow in via usb-serial connection of the USB-WDE1. But this shouldn't be too hard, I guess.
______________________________________________________
Mobile Phones Lenovo LePad S2005A Lenovo LePhone P700
