meteohub does not record data any more
Posted: Wed Oct 14, 2009 5:32 pm
by Manhart
My Meteohub does not record data from my VP2 since 1100 any more. Connection with internet is ok. When i check "data view", there are no data on display after 1530. Any idea ?
Matthias
http://www.beathis.ch/meteo/
Re:meteohub does not record data any more
Posted: Wed Oct 14, 2009 6:51 pm
by YJB
Just wondering, are the sensors still reporting new values on the sensor page?
Anything in the logs that gives a clue?
You might want to force a manual recompute on the maintenance page.
Posted: Wed Oct 14, 2009 7:53 pm
by Manhart
The sensor-page is online and the data from the VP2 are ok.
The page "data view" is dead. No new data after 1530.
A restart of the NSLU2 does not change anything. There is enough free space on the memory-stick.
The exported graphs are online, as you can see on my website.
meteohub.log and alarm.log don't show errors.
Now i made the update to 4.5d (build 12). The recalculation needs several hours. I will make it this night.
Matthias
Posted: Wed Oct 14, 2009 8:22 pm
I fear "dmesg log" will show errors regarding "sda3". If so, USB stick has gone.
I will add a new feature that makes a diagnosis of this automatically. While recent changes in Meteohub further reduce stress on USB sticks there seem to be very weak sticks around that are sure candidates for errors over time.
Unfortunately, there are nearly no SLC USB sticks around. For SheevaPlug (sd card) and x86 (CF card) there are SLC models around which can tahe factor 10 more writes than broader used (and much cheaper) MLC ones. Having SLC combined with storage media from brands with good reputation that have good wear leveling algorithms in place, I believe storage failures are unlikely to occur in the first 5 years of operation. Up to now I have heard of just one crashed CF card (was a cheap MLC one) and no problems with sd cards (but SheevaPlug is still fairly new).
Posted: Wed Oct 14, 2009 8:55 pm
by Manhart
The memory-stick is ok. I can write and delete files in /public/transfer (mounting the folder).
I did not find errors in dmes.log.
Matthias
Posted: Wed Oct 14, 2009 10:25 pm
could you please post dmesg log.
Posted: Wed Oct 14, 2009 10:26 pm
by Manhart
<4>CPU: XScale-IXP42x Family [690541f2] revision 2 (ARMv5TE), cr=000039ff
<4>Machine: Linksys NSLU2
<4>Memory policy: ECC disabled, Data cache writeback
<7>On node 0 totalpages: 8192
<7> DMA zone: 64 pages used for memmap
<7> DMA zone: 0 pages reserved
<7> DMA zone: 8128 pages, LIFO batch:0
<7> Normal zone: 0 pages used for memmap
<4>CPU0: D VIVT undefined 5 cache
<4>CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
<4>CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
<4>Built 1 zonelists. Total pages: 8128
<5>Kernel command line: rtc-x1205.probe=0,0x6f console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=jffs2 rw init=/linuxrc noirqdebug
<6>IRQ lockup detection disabled
<4>PID hash table entries: 128 (order: 7, 512 bytes)
<4>Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
<4>Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
<6>Memory: 32MB = 32MB total
<5>Memory: 30292KB available (1912K code, 153K data, 84K init)
<7>Calibrating delay loop... 266.24 BogoMIPS (lpj=1331200)
<4>Mount-cache hash table entries: 512
<6>CPU: Testing write buffer coherency: ok
<6>NET: Registered protocol family 16
<4>IXP4xx: Using 16MiB expansion bus window size
<4>PCI: IXP4xx is host
<4>PCI: IXP4xx Using direct access for memory space
<6>PCI: bus0: Fast back to back transfers disabled
<6>dmabounce: registered device 0000:00:01.0 on pci bus
<6>dmabounce: registered device 0000:00:01.1 on pci bus
<6>dmabounce: registered device 0000:00:01.2 on pci bus
<5>SCSI subsystem initialized
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>Time: OSTS clocksource has been installed.
<6>NET: Registered protocol family 2
<4>IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
<4>TCP established hash table entries: 1024 (order: 1, 8192 bytes)
<4>TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
<6>TCP: Hash tables configured (established 1024 bind 1024)
<6>TCP reno registered
<4>NetWinder Floating Point Emulator V0.97 (double precision)
<6>JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
<6>io scheduler noop registered
<6>io scheduler deadline registered (default)
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
<6>serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
<6>serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
<4>RAMDISK driver initialized: 4 RAM disks of 10240K size 1024 blocksize
<6>IXP4XX NPE driver Version 0.3.0 initialized
<6>NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
<6>IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
<7>IXP4XX-Flash.0: Found an alias at 0x800000 for the chip at 0x0
<4> Intel/Sharp Extended Query Table at 0x0031
<6>Using buffer write method
<5>cfi_cmdset_0001: Erase suspend on write enabled
<7>erase region 0: offset=0x0,size=0x20000,blocks=64
<5>Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
<5>6 RedBoot partitions found on MTD device IXP4XX-Flash.0
<5>Creating 6 MTD partitions on "IXP4XX-Flash.0":
<5>0x00000000-0x00040000 : "RedBoot"
<6>nslu2 mac: 00:1d:7e:b4:3f:45
<5>0x00040000-0x00060000 : "SysConf"
<5>0x00060000-0x00080000 : "Loader"
<5>0x00080000-0x00180000 : "Kernel"
<5>0x00180000-0x007e0000 : "Flashdisk"
<5>0x007e0000-0x00800000 : "FIS directory"
<4>npe: searching for firmware...
<6>npe: found at 0x1c010, IXP425/NPE-B func: 00, rev: 2.1, size: 11964, id: 01000201
<6>Image loaded to NPE-B Func:0, Rel: 2:1, Status: 82c00000
<6>Initializing USB Mass Storage driver...
<6>usbcore: registered new interface driver usb-storage
<6>USB Mass Storage support registered.
<6>input: ixp4xx beeper as /class/input/input0
<6>i2c /dev entries driver
<6>x1205 0-006f: chip found, driver version 1.0.7
<6>x1205 0-006f: rtc core: registered x1205 as rtc0
<6>Registered led device: ready
<6>Registered led device: status
<6>Registered led device: disk-1
<6>Registered led device: disk-2
<6>TCP cubic registered
<6>NET: Registered protocol family 17
<6>XScale DSP coprocessor detected.
<6>x1205 0-006f: setting the system clock to 2009-10-14 19:49:57 (1255549797)
<4>VFS: Mounted root (jffs2 filesystem).
<6>Freeing init memory: 84K
<4>PCI: enabling device 0000:00:01.2 (0140 -> 0142)
<6>ehci_hcd 0000:00:01.2: EHCI Host Controller
<6>ehci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
<6>ehci_hcd 0000:00:01.2: irq 26, io mem 0x48002000
<6>ehci_hcd 0000:00:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
<6>usb usb1: configuration #1 chosen from 1 choice
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 5 ports detected
<7>ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
<4>PCI: enabling device 0000:00:01.0 (0140 -> 0142)
<6>ohci_hcd 0000:00:01.0: OHCI Host Controller
<6>ohci_hcd 0000:00:01.0: new USB bus registered, assigned bus number 2
<6>ohci_hcd 0000:00:01.0: irq 28, io mem 0x48000000
<6>usb usb2: configuration #1 chosen from 1 choice
<6>hub 2-0:1.0: USB hub found
<6>hub 2-0:1.0: 3 ports detected
<4>PCI: enabling device 0000:00:01.1 (0140 -> 0142)
<6>ohci_hcd 0000:00:01.1: OHCI Host Controller
<6>ohci_hcd 0000:00:01.1: new USB bus registered, assigned bus number 3
<6>ohci_hcd 0000:00:01.1: irq 27, io mem 0x48001000
<6>usb usb3: configuration #1 chosen from 1 choice
<6>hub 3-0:1.0: USB hub found
<6>hub 3-0:1.0: 2 ports detected
<6>usb 1-2: new high speed USB device using ehci_hcd and address 3
<6>usb 1-2: configuration #1 chosen from 1 choice
<6>scsi0 : SCSI emulation for USB Mass Storage devices
<7>usb-storage: device found at 3
<7>usb-storage: waiting for device to settle before scanning
<6>usb 2-1: new full speed USB device using ohci_hcd and address 2
<6>usb 2-1: configuration #1 chosen from 1 choice
<5>scsi 0:0:0:0: Direct-Access SanDisk Cruzer 4.05 PQ: 0 ANSI: 2
<5>SCSI device sda: 16055949 512-byte hdwr sectors (8221 MB)
<5>sda: Write Protect is off
<7>sda: Mode Sense: 03 00 00 00
<3>sda: assuming drive cache: write through
<6> sda: sda1 sda2 sda3
<5>sd 0:0:0:0: Attached scsi removable disk sda
<7>usb-storage: device scan complete
<6>kjournald starting. Commit interval 5 seconds
<4>EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
<6>EXT3 FS on sda1, internal journal
<6>EXT3-fs: mounted filesystem with ordered data mode.
<6>usbcore: registered new interface driver usbserial
<6>IXP4XX Q Manager 0.2.1 initialized.
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
<6>usbcore: registered new interface driver usbserial_generic
<6>drivers/usb/serial/usb-serial.c: USB Serial Driver core
<6>ixp4xx_mac driver 0.3.1: eth0 on NPE-B with PHY[1] initialized
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
<6>pl2303 2-1:1.0: pl2303 converter detected
<6>usb 2-1: pl2303 converter now attached to ttyUSB0
<6>usbcore: registered new interface driver pl2303
<6>drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
<6>EXT3 FS on sda3, internal journal
<6>Adding 131064k swap on /dev/sda2. Priority:-1 extents:1 across:131064k
<6>eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
<7>Link of eth0 is full-duplex
<4>IXP4xx Watchdog Timer: heartbeat 60 sec
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
<6>usbcore: registered new interface driver cp2101
<6>drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
<6>usbcore: registered new interface driver ftdi_sio
<6>drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
USB:
Bus 2 Device 2: ID 0557:2008
Bus 2 Device 1: ID 0000:0000
Bus 3 Device 1: ID 0000:0000
Bus 1 Device 1: ID 0000:0000
Bus 1 Device 3: ID 0781:5204
PCI:
00:01.0 0c03: 1033:0035 (rev 43)
00:01.1 0c03: 1033:0035 (rev 43)
00:01.2 0c03: 1033:00e0 (rev 04)
iPartitions:
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/sda1 412524 221790 169436 57% /
/dev/mtdblock4 6528 5592 936 86% /initrd
/dev/sda1 412524 221790 169436 57% /dev/.static/dev
tmpfs 2048 32 2016 2% /dev
/dev/sda3 3256488 613672 2477392 20% /data
tmpfs 15188 328 14860 2% /var/volatile
tmpfs 15188 0 15188 0% /dev/shm
Process:
PID Uid VmSize Stat Command
1 root 572 S init [3]
2 root SWN [ksoftirqd/0]
3 root SW< [events/0]
4 root SW< [khelper]
5 root SW< [kthread]
38 root SW< [kblockd/0]
41 root SW< [khubd]
56 root SW [pdflush]
57 root SW [pdflush]
58 root SW< [kswapd0]
59 root SW< [aio/0]
81 root SW [mtdblockd]
82 root SW [nftld]
171 root SW< [scsi_eh_0]
172 root SW< [usb-storage]
199 root SW< [kjournald]
245 root 616 S < udevd --daemon
626 root DW< [kjournald]
924 daemon 424 S /sbin/portmap
1068 root 820 R N /home/meteohub/wmr928eval -n -c min1 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -e /home/meteohub
1071 root 620 S N /home/meteohub/wmr928eval -n -c min1 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -E /home/meteohub
1085 root 448 S /home/meteohub/watchdog
1092 root 784 S /home/meteohub/meteoschedule /dev/meteohub
1117 root 712 R N /srv/www/meteolog.cgi 0 0
1143 root 908 S /usr/sbin/sshd
1152 root 344 S /home/meteohub/loggerd /var/run/loggerd.pid
1153 root 1472 S /home/meteohub/loggerd /var/run/loggerd.pid
1201 root 2068 S N /usr/sbin/smbd
1204 root 1144 S /usr/sbin/nmbd
1214 root 1016 S /usr/sbin/thttpd -C /etc/thttpd.conf
1220 root 808 S /usr/sbin/thttpdbackup -C /etc/thttpd-backup.conf
1227 root 868 S /home/meteohub/meteonet -r
1233 root 1024 S /usr/bin/ntpd -p /var/run/ntpd.pid -g
1242 root 556 S /usr/bin/rsync /var/run/rsyncd.pid --daemon
1250 root 700 S /usr/sbin/cron
1266 root 1588 S N /usr/sbin/smbd
1278 root 544 S /sbin/getty 115200 ttyS0
1584 root 652 S /bin/sh /home/meteohub/wmr928fulleval
4348 root 816 R N /home/meteohub/wmr928eval -n -c min10 -w /data/weather/ -s /home/meteohub/wmr928fulleval.do.conf
6748 root 460 S /USR/SBIN/CRON
6749 root 596 S /bin/sh -c sleep 90; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph tint1_1m >/v
6750 root 460 S /USR/SBIN/CRON
6752 root 596 S /bin/sh -c sleep 85; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph tint1_6m >/v
6753 root 460 S /USR/SBIN/CRON
6754 root 596 S /bin/sh -c sleep 80; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph tintt1_7d >/
6755 root 460 S /USR/SBIN/CRON
6756 root 596 S /bin/sh -c sleep 75; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph tint1_24h >/
6760 root 540 S sleep 90
6773 root 540 S sleep 80
6774 root 540 S sleep 75
6776 root 540 S sleep 85
6803 root 488 S /USR/SBIN/CRON
6804 root 592 S /bin/sh -c /bin/pidof histeval1 || /usr/bin/nice /home/meteohub/histeval1
6822 root Z [cron]
6823 root 644 S N /bin/sh /home/meteohub/histeval1
6829 root 724 R N /home/meteohub/wmr928eval -c day1 -t -100000 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -H
6860 root 460 S /USR/SBIN/CRON
6861 root 596 S /bin/sh -c sleep 35; [ -z "`ls /data/uploads/`" ] || [ -n "`/bin/pidof /usr/bin/ncftpput`" ] || /usr/bin/n
6869 root 540 S sleep 35
6904 root 1400 S < meteohub.cgi
6905 root 492 S /usr/sbin/thttpd -C /etc/thttpd.conf
6929 root 796 R < ps w
Posted: Wed Oct 14, 2009 10:42 pm
hm, looks ok.
could you please open a ssh-tunnel to me by "htt://ip-of-your-meteohub/cgi-bin/help.cgi"? This would allow me to login and look myself.
Posted: Wed Oct 14, 2009 11:18 pm
by Manhart
channel is open.
Posted: Thu Oct 15, 2009 12:26 pm
by Manhart
The system is ok after recalculating the data.
Matthias
