Problem changing Meteohub IP address
Posted: Thu Oct 15, 2009 8:48 pm
by kalibby897
I need to change my Meteohub IP address to a different subnet. When I put in the new IP address and gateway info and reboot the meteohub, I keep getting the same IP address that was input previously. If I change my router info and set meteohub to use DHCP, I still get the IP that was used when I set it earlier via manual IP address. Running 4.5c
Re:Problem changing Meteohub IP address
Posted: Thu Oct 15, 2009 9:35 pm
switch of dhcp, make your settings, press "save" and ignore what meteohub displays after having pressed save.
Reboot and changes will be effective as planned.
Posted: Thu Oct 15, 2009 9:38 pm
by kalibby897
Did that and still keep getting the OLD IP address. I can hear it from the beeps when Meteohub reboots
Posted: Thu Oct 15, 2009 9:47 pm
that is strange.
Posted: Thu Oct 15, 2009 10:41 pm
by kalibby897
Agreed. I'm not a dope so lets see if we can figure this out. Its very strange
Posted: Thu Oct 15, 2009 11:45 pm
by YJB
I'm wondering if you are having an issue with updating the configuration file, might be that write permission is no longer there.
try to run a cat /etc/network/interfaces from the meteohub command line, to see what is defined.
If it is a static address you will see towards the end of the file something like:
iface eth0 inet static
address 192.168.0.12
netmask 255.255.255.0
gateway 192.168.0.1
If it is DHCP it will be:
iface eth0 inet dhcp
address 192.168.1.77
Posted: Fri Oct 16, 2009 12:42 am
by kalibby897
OK will do
