Cannot Locate clientraw.txt
Posted: Sat Jan 23, 2010 2:39 pm
by funteck
I'm running Metoehub on the NSLU2. When I load WD Live I get Error Loading Data page and I can't find the /myweb/uploads/clientraw.txt file. How can I confirm where this file should be created and/or troubleshoot this. I also wanted to find out any information on hosting a simple website on NSLU2 or if that is possible. Thanks for any help!
Re:Cannot Locate clientraw.txt
Posted: Sat Jan 23, 2010 10:59 pm
by wfpost
best way is to map the meteohub drive as network drive on your Windows PC
doing it without explorer´s gui, you can use the windows command line.
go to run and type cmd
with the new window that opened type
net use m: \\\\meteohub\\public meteohub /user:meteohub
this maps drive letter M: of the meteohub Samba share with your local computer.
now open drive M: in explorer and you will see the clientrwaw.txt in subfolder
M:\\myweb\\uploads
you could also create a new link on your desktop with this command
%windir%\\system32\\net.exe use m: \\\\meteohub\\public meteohub /user:meteohub
You can use a different drive letter than M:, but it has to be free.
C: D: E: F: normally in use by local drives.
