AR5005G use in meteohub ?
czappi
Post by czappi » Mon Feb 22, 2010 5:32 pm
can i use Atheros Communications, Inc. AR5005G 802.11abg (rev 01)
with meteohub ??
czappi
Re:AR5005G use in meteohub ?
Post by czappi » Mon Feb 22, 2010 6:17 pm
ndiswrapper version 1.53 loaded (smp=no, preempt=no)
Feb 22 17:09:14 localhost kernel: ndiswrapper: driver net5211 () loaded
Feb 22 17:09:14 localhost kernel: ndiswrapper (ZwClose:2198): closing handle 0xce5591c8 not implemented
Feb 22 17:09:14 localhost kernel: PCI: Setting latency timer of device 0000:00:0c.0 to 64
Feb 22 17:09:14 localhost kernel: ndiswrapper (NdisMAllocateMapRegisters:971): Windows driver net5211 requesting too many (256) map registers
Feb 22 17:09:14 localhost kernel: ndiswrapper: using IRQ 9
Feb 22 17:09:14 localhost kernel: wlan0: ethernet device 00:80:48:3b:b6:89 using serialized NDIS driver: net5211, version: 0x50001, NDIS version: 0x501, vendor: '', 168C:001A:168C:2052.5.conf
Feb 22 17:09:14 localhost kernel: wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
Feb 22 17:09:14 localhost kernel: usbcore: registered new interface driver ndiswrapper
Feb 22 17:09:14 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Feb 22 17:09:14 localhost kernel: NET: Registered protocol family 10
Feb 22 17:09:14 localhost kernel: lo: Disabled Privacy Extensions
Feb 22 17:09:14 localhost kernel: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Post by admin » Mon Feb 22, 2010 11:22 pm
Have a look here:
http://www.meteohub.de/joomla/index.php ... 22&id=4530
What is PCI vendor/product ID?
czappi
Post by czappi » Tue Feb 23, 2010 9:53 am
00:0c.0 0200: 168c:001a (rev 01)
00:0c.0 Ethernet controller: Atheros Communications, Inc. AR5005G 802.11abg NIC (rev 01)
Post by admin » Tue Feb 23, 2010 10:47 am
that should do :-)
czappi
Post by czappi » Tue Feb 23, 2010 11:28 am
but Its not work
:S
Chris
czappi
Post by czappi » Sun Feb 28, 2010 9:53 pm
Why do I get no response?
Here is a forum where gets no help ?
Post by admin » Tue Mar 02, 2010 9:47 am
What Meteohub version are you running? What Platform?
czappi
Post by czappi » Tue Mar 02, 2010 11:56 am
Meteohub 4.6b (Build 2593)
on ALIX.3D2
I have system new install with the same problem
Post by admin » Tue Mar 02, 2010 4:52 pm
Are WLAN-Options displayed when opening "network" page?
What PCI Vendor/Product IDs does Meteohub report on page "Log Files", selection "dmesg", section "PCI"?
Post by admin » Tue Mar 02, 2010 5:58 pm
The adapter is supported correctly by Meteohub 4.6b
I took time to take actual USB stick install image for x86 and extracted image.bin from it as explained in the manual in section 1.2
I flashed image.bin to CF card and put the CF card into my ALIX.3D2 with AR5005G adapter. System starts ok, I made WLAN settings (WAP) and started again with LAN disconnected. System can be reached via WLAN with no problem.
So problem must be with your kind of handling/installation or your rig is faulty. May be you might share a bit more detail how you are trying to get WLAN working. I guess you are wrong on that.
