How to fix old bad data record?
Posted: Sun Mar 14, 2010 4:16 pm
by cbhiii
I'm getting this error in my meteohub log:
[*]wmr928eval (14.03.2010 04:56:23): illegal data record in line 343764 while reading from file /data/weather/200901/raw: 20090112nd0 201 18 13 -081
When I got back to January 2009 and click clean up data, I get this error.
[*]Error: Cleanup of raw data for month "2009-01" failed.
How should I go and clean this up?
Re:How to fix old bad data record?
Posted: Sun Mar 14, 2010 4:23 pm
by wfpost
have you stopped data recording on the maintainance menu?
Posted: Sun Mar 14, 2010 4:28 pm
by skyewright
cbhiii wrote:How should I go and clean this up?
I'd make a copy of the raw file for January (on the basis that it's always handy to have an extra backup!), then open the original in a text editor and search for the error, using the error message as a guide.
Assuming that you can spot the error, edit out the bad line(s) and save the file.
You might then want to do a recomputation.
I suppose that you perhaps ought to halt logging while doing the edits, but personally I only do that if I'm editing the current month's raw file.
Posted: Sun Mar 14, 2010 4:46 pm
by cbhiii
Thanks Skyewright. Thanks a good idea.
