Page 1 of 2
THSW index
Posted: Fri Apr 09, 2010 7:45 pm
by EmjayNet
I prefer the THSW index given on the VP2 console as the feels-like temperature.
Is there any way for MH to extract this value out of the console?
Re: THSW index
Posted: Thu Sep 01, 2011 9:54 pm
by Hathor27
Me too...
...how could we get THSW index out of Vantage Pro2?
Is it somehow covered in meteohub, or is it not yet implemented?
Re: THSW index
Posted: Fri Dec 02, 2011 9:07 pm
by Hathor27
Calling to admin : Is there any chance to get this THSW index out of Davis Vantage ??
Re: THSW index
Posted: Sun Jan 01, 2012 4:47 pm
by EmjayNet
Yep would love to see this added to the list a things to add!
I know there are less vantage users but i would be nice to have 1 thing I requested added to software if it at all possible, please boris!
Re: THSW index
Posted: Mon Jan 02, 2012 12:07 am
by d_l
The THSW index is re-calculated by the WeatherLink software and
not simply output by the Davis hardware in the LOOP data to the WL software. Note that there is even an option in the WeatherLink software to re-calculate the THSW index after some of its input data values have been altered. The HI/LOW data does output the Day High THSW and the
Time of Day High THSW, but this isn't what you would want. Therefore, any implementation of the the index would have to be re-calculated by the Meteohub from the component data.
The formula for the THSW can be found in this
Davis application note
Re: THSW index
Posted: Mon Jan 02, 2012 12:15 am
by skyewright
EmjayNet wrote:Yep would love to see this added to the list a things to add!
THSW is what I have my VP2 console set to show as "feels like" too. It would be nice to be able to log it...
Re: THSW index
Posted: Mon Jan 02, 2012 3:14 pm
by EmjayNet
Normally everything on the console is availiable in the LOOP, it would seem odd if this console output was not in the LOOP but who knows with Davis.
Unless someone here has the output of the LOOP, then I guess only Boris can answer this!
Re: THSW index
Posted: Mon Jan 02, 2012 3:24 pm
by YJB
EmjayNet wrote:Normally everything on the console is availiable in the LOOP, it would seem odd if this console output was not in the LOOP but who knows with Davis.
From the Davis interface manual:
Only values read directly from sensors are included in the LOOP packet
From the Davis App note 28 document:
The following parameters do not have any sensors or circuitry. They are calculated from measured variables.
<SNIP>
THSW INDEX
Parameters Used: Temperature, Humidity, Solar Radiation, Wind Speed, Latitude & Longitude, Time and Date
<SNIP>
THSW is available in the HIGHLOW packet, but since that will only list extremes it will not be suitable to satisfy the requirement listed above:
Day High THSW 95 2
Time of Day High THSW 97 2
Month High THSW 99 2
Year High THSW 101 2
Ysbrand
Re: THSW index
Posted: Mon Jan 02, 2012 3:45 pm
by EmjayNet
I stand corrected. What a pity!
It so nice to visit such a friendly place every now and then.
Have a good year all.
Re: THSW index
Posted: Mon Jan 02, 2012 4:01 pm
by Hathor27
If there's no direct output within the LOOP, couldn't we rebuild THSW manually ? The application just talks about
series of formulas used to.
Does anybody know how we could calculate it as a virtual sensor from its based values?
Re: THSW index
Posted: Mon Jan 02, 2012 7:38 pm
by d_l
Hathor27 wrote:
Does anybody know how we could calculate it (THSW) as a virtual sensor from its based values?
I have more details on the THSW calculation from a Davis VP Tech manual than is offered in App Note 28. Unfortunately it is in PDF format and is over a megabyte in size. I'll try to condense the size or format some how and post it here when I get the time -- the next day or so.
Suffice it to say that calculating it as a virtual sensor with AWK will be tricky as the wind factor is from several look up tables and the solar factor is a sum of four complicated equations with If/Then complicating limits on the raw data and not just simple "terms" as AN 28 states.
Re: THSW index
Posted: Mon Jan 02, 2012 9:35 pm
by Hathor27
d_l wrote:I'll try to condense the size or format some how and post it here when I get the time -- the next day or so.
Would you mind sending me the original file as private message (email) or posting just a link here?
Re: THSW index
Posted: Mon Jan 02, 2012 10:15 pm
by YJB
Hathor27 wrote:d_l wrote:I'll try to condense the size or format some how and post it here when I get the time -- the next day or so.
Here you go (directly from the source):
http://davisnet.com/product_documents/w ... iables.pdf
THSW starts at page 28-7
Also, one needs to be very careful when starting to make calculations on the fly, especially when using a virtual sensor. Think about the cpu resources needed every time the "trigger" sensor is being updated. One will be forced to use something like "C", otherwise this is not going to fly.
Ysbrand
Re: THSW index
Posted: Mon Jan 02, 2012 10:42 pm
by Hathor27
Thank you, Ysbrand, I know about that application note - but
d_l wrote about
Davis VP Tech manual and
over a megabyte. I think that would be something more precise - the application note doesn't describe the exact formula.
YJB wrote:Also, one needs to be very careful when starting to make calculations on the fly, especially when using a virtual sensor. Think about the cpu resources needed every time the "trigger" sensor is being updated. One will be forced to use something like "C", otherwise this is not going to fly.
If we know more details about the formula, we can probably estimate the required recources...
Re: THSW index
Posted: Wed Jan 04, 2012 12:05 am
by d_l
AFAIK, there is no public link to this VP tech manual. The entire manual is over 5 megabytes. I tried extracting just the THSW section and ended up with a one megabyte PDF file. I tried taking images of the section but they had to be pixel huge on each side to be legible. Extraction to txt or RTF formats really scrambled the text. So I upgraded my program (it isn't Acrobat), and tried again. I had to break it down and zip it to be under the permitted size limit and in an allowable format.
