				Update 4.6h
				Posted: Tue May 11, 2010 8:31 pm
				DEUTSCH:
Update V4.6h (NSLU2, x86, SheevaPlug) enthält die folgenden Änderungen:
* Beseitigt einen Fehler bei der Auswahl der Windchill-Berechnung.
* Beseitigt einen Fehler beim Import von WSWIN Daten bezüglich des Windchills.
* Beseitigt einen Bezeichnungsfehler bei den rapid fire Einstellungen des Wetternetzwerks "weatherflow".
* Beseitigt einen Fehler, der zu hoher Systemlast bei der Aktivierung von "rapid fire" beim Wetternetzwerk Weather Underground führen kann.
ENGLISH:
Update to Meteohub V4.6h (NSLU2, x86, SheevaPlug) brings these features:
* Fixes a bug when choosing windchill calculation modes.
* Fixes a bug concerning windchill when using WSWIN import function.
* Fixes a bug in naming rapid fire options of weather network "weatherflow".
* Fixes a bug that can cause high system load when driving weather network "Weather Underground" in rapid fire mode.
LINK:
				Re:Update 4.6h
				Posted: Wed May 12, 2010 4:34 pm
				by Periklast
				Can you also try to solve the solar-plugin problem?
http://www.meteohub.de/joomla/index.php ... itstart=18
Plugin can read solar-data until you give it an id (sol0-sol1-...). Than the whole plugin stops working.
I'm not the only one with that problem. Other data (like uv, t0,..) works correct, it's only the solar that gives problems.
				Re:Update 4.6h
				Posted: Wed May 12, 2010 4:44 pm
				Plugin reports ASCII data on stdout. Could you please send me a snippet of these output data, that streams in to Meteohub.
Without that it is hard to test.
				Re:Update 4.6h
				Posted: Wed May 12, 2010 7:56 pm
				by Periklast
				Do you mean this? Or where do I find the output data?:
More information can be found in the topiclink I posted in previous post.
				Re:Update 4.6h
				Posted: Wed May 12, 2010 8:14 pm
				by VP2
				Hi
     Updated to 4.6h yesterday (11/5) WU Rapidfire no longer updating, status is noted as Normal on WU Rapidfire is set on and to 5sec but seems to be updating at 5min intervals. any help ideas.
 Thanks   Alan WU ITRAFFOR2
				Re:Update 4.6h
				Posted: Thu May 13, 2010 10:15 am
				That's a bug. I just fixed it. When you download and install 4.6h again, problem should be solved.
				Re:Update 4.6h
				Posted: Thu May 13, 2010 1:04 pm
				I just made a fix for the plugin issue. When you install latest version of 4.6h, the problem should be gone.
x86 build:  3359
SheevaPlug build: 118
NSLU2 build: 114
				Re:Update 4.6h
				Posted: Thu May 13, 2010 10:33 pm
				by Periklast
				At first sight, it seems to work!
Thanks!
				Re:Update 4.6h
				Posted: Mon May 17, 2010 5:49 pm
				by rovinj
				Hello. How can I revert to 4.6g?
Yesterday I experienced problems with sensors and WAN connection on my NSLU2 after I upgrade to this version.
				Re:Update 4.6h
				Posted: Mon May 17, 2010 8:58 pm
				you can download 4.6g manually from the link given in the announcement. This Link also explains how to do a manually update (file-based method).
But I don't believe 4.6h being responsible for the problems. High server load during recomputation after an update can have an impact on your NSLU2 or some so far hidden USB stick troubles have been made apparent during installation.
				Re:Update 4.6h
				Posted: Sun Jun 20, 2010 5:52 pm
				by rainman110
				One thing that appears to have broken for me with 4.6h is that my extra temperature sensor t1 (Davis Vantage Pro 2) no longer reports the daily high and low in the data, all I get is the current temperature, so my WDL </txtInstExtra1TempMinMax> instrument no longer reports the daily high and low.  My other temperature sensors still report this data normally.  The raw data inspection would seem to support this as I notice that the only value given for sensor t1 is the current value.
This function has malfunctioned since about the time I updated to 4.6h, so it is the only thing that has changed that I can think of that might be the cause.  I would downgrade to 4.6g to test this theory, but these sensors are at a remote site that I have yet to visit to try a manual downgrade.
I noticed some other similar comments about things broken in the WDL forum threads with 4.6h, so I thought I would mention it here.
				Re:Update 4.6h
				Posted: Sun Jun 20, 2010 7:00 pm
				I can't remember having changed something there. However, when you browse to "
http://your-meteohub-ip/cgi-bin/help.cgi" this will open a ssh tuunnel to me, which allows me to have a look at your rig myself.
				Re:Update 4.6h
				Posted: Sun Jun 20, 2010 11:00 pm
				no problem with meteohub sw, but with your usb stick which shows massive problems in dmesg log:
<4>end_request: I/O error, dev sda, sector 417780
<6>sd 0:0:0:0: SCSI error: return code = 0x08000002
<6>sda: Current: sense key=0x3
<6>    ASC=0x11 ASCQ=0x0
and "meteohub log" also displays errors when trying to read data from the stick:
wmr928eval (20.06.2010 13:55:29): illegal data record in line 289253 while reading from file /data/weather/200902/raw: r0090220204552 wind0 154 4 18 0069
wmr928eval (20.06.2010 13:55:29): illegal data record in line 289260 while reading from file /data/weather/200902/raw: 2009222020456 wind0 182 13 18 0064
wmr928eval (20.06.2010 13:55:29): illegal data record in line 289264 while reading from file /data/weather/200902/raw: "0090220204608 wind0 186 13 18 0064
wmr928eval (20.06.2010 13:55:29): illegal data record in line 289279 while reading from file /data/weather/200902/raw: 200902�0204700 wind0 186 9 18 0070
wmr928eval (20.06.2010 13:55:29): illegal data record in line 289281 while reading from file /data/weather/200902/raw: 20�90220204704 wind0 186 9 18 0070
wmr928eval (20.06.2010 13:55:29): illegal data record in line 289289 while reading from file /data/weather/200902/raw: 200902�0204728 wind0 186 4 18 0071
