Incorect temperature history
Posted: Sat Jun 26, 2010 6:56 pm
by flweathergeek
First off Im not sure if this is a meteohub issue or a weather display live issue. My weather station over at http://weather.kevinsdomain.com that I just setup does not want to display the correct records in both the temperature graph and for the all time records. I'm not sure where to begin at trouble shooting this since everything else seems to work fine including the current temps. Any help would be greatly appreciated.
Re:Incorect temperature history
Posted: Sun Jun 27, 2010 2:45 pm
by flweathergeek
Messing with the settings I have been able to get the graphs to begin to display the data. It turns out I was not uploading clientrawdaily.txt clientrawextra.txt and clientrawhour.txt Now the only problem seems to be that my 24 hour history graph seems to lag a hour or more behind but the last hour graphs are relatively up to date. I have the setting currently set to upload the clientrawdaily.txt clientrawextra.txt and clientrawhour.txt files every 5 mins
