total rain from yesterday?
Posted: Wed Aug 18, 2010 7:23 am
by AenG
I can use serveral variable's to display the rain value. But i can find a variable to display the total rain from yesterday.
How can i do that?
gr Geert
www.hetweerinboskamp.nl
Re: total rain from yesterday?
Posted: Wed Aug 18, 2010 1:51 pm
by EmjayNet
I get mine by using:
[seqday1_rain0_total_mm]
You can use the @ to select which value you want from the range (e.g. [seqday1_rain0_total_mm@1])
Hope that helps?
Posted: Wed Aug 18, 2010 3:10 pm
by AenG
That works fine :D
Thanks for help.
Geert
Posted: Sun Aug 22, 2010 1:36 pm
by cgn
I saw this topic and it's quite interesting to use the seqday1 variable to get values from yesterday.
I didn't know this before because this variable is not described in the manual.
After testing this variable I noticed that seqday1 in combination with min or max only gives values of
temperature (e.g. [seqday1_th0_tempmin_c] returns the min temp from the last days).
But [seqday1_th0_dewmin_c] or [seqday1_thb0_sealevelmax_hpa] are not implemented.
Is there another way to get min and max values from former days (or months)?
Posted: Sun Aug 22, 2010 1:53 pm
by EmjayNet
I don't really know what variables are availble to all MH's because it differs with station type, etc..
I also use:
http://[your-ip-address]/meteograph.cgi?text=all
This give you a complete list of whats availible on your MH.
You can get some min/max from seqday1 but these are for temperature.
Posted: Sun Aug 22, 2010 2:51 pm
by cgn
Thanks for your answer.
With "...text=all" I can see that the seq... variables in combination with min/max are only available for the temperature.
So it seems that there is no solution for my problem.
