Latest Meteohub Update not reading Pro 2 sensor data
Posted: Wed Nov 24, 2010 7:37 pm
by dabird22
I have had NSLU2 running for a couple years. I recently had to redo my memory stick. After upgrading, I am not able to read my Davis Pro 2 sensors. I have also tried the VMware image of meteohub and it is not working either. I think it may be a bug with trying to read the davis data logger. Here is what I get in the Meteohub log:
logger (24.11.2010 11:21:15): station 0 (Vantage), syncing.
logger (24.11.2010 11:21:25): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (24.11.2010 11:21:25): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (24.11.2010 11:21:25): station 0 (Vantage), transmitter 2 active as station type (#0) "ISS".
logger (24.11.2010 11:21:30): station 0 (Vantage), data gap of 12335 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
logger (24.11.2010 11:21:36): station 0 (Vantage), data gap of 12335 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
logger (24.11.2010 11:21:41): station 0 (Vantage), data gap of 12335 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
logger (24.11.2010 11:21:47): station 0 (Vantage), data gap of 12335 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
logger (24.11.2010 11:21:47): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.11.2010 11:21:47): station 0 (Vantage), syncing.
logger (24.11.2010 11:21:58): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (24.11.2010 11:21:59): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (24.11.2010 11:21:59): station 0 (Vantage), transmitter 2 active as station type (#0) "ISS".
logger (24.11.2010 11:22:08): station 0 (Vantage), data gap of 12336 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
loggereval (24.11.2010 11:22:11): illegal data record in line 564 while reading from file /data/weather/201011/raw: 20101115140100 rain0 0 0 18��F�r@{Cr�@��?�͕loggereval (24.11.2010 11:22:11): illegal data record in line 565 while reading from file /data/weather/201011/raw: ��?�͕logger (24.11.2010 11:22:13): station 0 (Vantage), data gap of 12336 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
logger (24.11.2010 11:22:19): station 0 (Vantage), data gap of 12336 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
logger (24.11.2010 11:22:24): station 0 (Vantage), data gap of 12336 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
logger (24.11.2010 11:22:25): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.11.2010 11:22:25): station 0 (Vantage), syncing.
logger (24.11.2010 11:22:36): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (24.11.2010 11:22:36): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (24.11.2010 11:22:36): station 0 (Vantage), transmitter 2 active as station type (#0) "ISS".
logger (24.11.2010 11:22:45): station 0 (Vantage), data gap of 12336 minutes, start reading Vantage's internal logger after 2010-11-15 21:45 (Vantage's local time).
Sensors show no data ever... But system info page shows data last 6 mins??
Type # ID Name Last Signal Sensor Data
wind 0 never -
rain 0 never -
indoor 0 never -
outdoor 0 never -
Process
Weather Data Recomputation: completed
Weather Data Logging: running (last data: 6 min)
Weather Network "Rapid Fire": running
SSH Login: running
SMB Shares: running
Time Synchonization: running
Anyone else having trouble? Any ideas to fix?
Re: Latest Meteohub Update not reading Pro 2 sensor data
Posted: Wed Nov 24, 2010 7:55 pm
which version? 4.6r? 4.6s? 4.6s-experimental?
Posted: Wed Nov 24, 2010 8:30 pm
by dabird22
4.6s... Updated from maintenance - Software Update (Auto)
I just checked auto update and saw there is the 4.6s-experimental...
I did not know there was a newer one out! sorry! It does look like that fixed my problem with my Davis and is now reading the sensors on my Vmware test setup.
Do you know if I will have any problems with a usb hard drive and meteohub on the NSLU2? I have the system up and running and now with this latest update... everything appears to be working.
Thank you Sir for your help and quick reply!
Posted: Wed Nov 24, 2010 10:25 pm
by dabird22
I stopped data logging for a bit to clean up raw data and now I am getting this...
logger (24.11.2010 14:20:29): station 0 (Vantage), syncing.
logger (24.11.2010 14:20:40): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (24.11.2010 14:20:40): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (24.11.2010 14:20:40): station 0 (Vantage), transmitter 2 active as station type (#0) "ISS".
logger (24.11.2010 14:20:49): station 0 (Vantage), data gap of 14 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:20:55): station 0 (Vantage), data gap of 14 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:21:01): station 0 (Vantage), data gap of 15 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:21:06): station 0 (Vantage), data gap of 15 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:21:07): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.11.2010 14:21:07): station 0 (Vantage), syncing.
logger (24.11.2010 14:21:17): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (24.11.2010 14:21:17): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (24.11.2010 14:21:17): station 0 (Vantage), transmitter 2 active as station type (#0) "ISS".
logger (24.11.2010 14:21:22): station 0 (Vantage), data gap of 15 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:21:28): station 0 (Vantage), data gap of 15 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:21:33): station 0 (Vantage), data gap of 15 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:21:39): station 0 (Vantage), data gap of 15 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:21:39): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.11.2010 14:21:39): station 0 (Vantage), syncing.
Any idea why it would be getting stuck on downloading the data? I dont get any sensor data while it is stuck.
Posted: Wed Nov 24, 2010 11:03 pm
by dabird22
I was poking around on the inspect data page and all of a sudden it started working. Looks like it finally downloaded from the davis logger. Coincidence?
I did not touch or do anything else.
ogger (24.11.2010 14:43:27): station 0 (Vantage), syncing.
logger (24.11.2010 14:43:37): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (24.11.2010 14:43:37): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (24.11.2010 14:43:37): station 0 (Vantage), transmitter 2 active as station type (#0) "ISS".
logger (24.11.2010 14:43:42): station 0 (Vantage), data gap of 37 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:43:47): station 0 (Vantage), data gap of 37 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:43:53): station 0 (Vantage), data gap of 37 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:43:58): station 0 (Vantage), data gap of 37 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:43:58): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.11.2010 14:43:58): station 0 (Vantage), syncing.
logger (24.11.2010 14:44:19): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (24.11.2010 14:44:19): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (24.11.2010 14:44:19): station 0 (Vantage), transmitter 2 active as station type (#0) "ISS".
logger (24.11.2010 14:44:24): station 0 (Vantage), data gap of 38 minutes, start reading Vantage's internal logger after 2010-11-24 14:05 (Vantage's local time).
logger (24.11.2010 14:44:24): station 0 (Vantage), internal logger provides 2 pages of data.
logger (24.11.2010 14:44:25): station 0 (Vantage), finished reading internal logger, 7 records inserted.
Posted: Wed Dec 15, 2010 4:30 pm
by Jippe
I have same problem. "Warning: Weather station does not have a sensor assigned on "Sensors" page"
meteohub.log
2010.12.15 16:08:35 log file cleared by user
logger (15.12.2010 16:08:39): station 0 (Vantage), gettime request sent.
logger (15.12.2010 16:08:50): station 0 (Vantage), gettime request sent.
logger (15.12.2010 16:08:59): parent process received termination signal (15).
logger (15.12.2010 16:08:59): child process received termination signal (15).
logger (15.12.2010 16:09:00): station 0 (Vantage), gettime request sent.
logger (15.12.2010 16:09:00): disconnect station 0 (Vantage).
logger (15.12.2010 16:09:00): data logger stopped.
logger (15.12.2010 16:09:53): data logger (version 4.6u, build 205) started.
logger (15.12.2010 16:09:55): connect station 0 (Vantage via USB serial).
logger (15.12.2010 16:09:56): station 0 (Vantage), wakeup sent.
logger (15.12.2010 16:09:56): station 0 (Vantage), syncing.
logger (15.12.2010 16:09:56): station 0 (Vantage), gettime request sent.
wmr928fulleval(15.12.2010 16:10:00): recomputation of weather data started.
wmr928fulleval(15.12.2010 16:10:02): recomputation of weather data finished: 0 records processed in 2 seconds (0 records per second)
logger (15.12.2010 16:10:06): station 0 (Vantage), gettime request sent.
logger (15.12.2010 16:21:21): station 0 (Vantage), gettime request sent.
logger (15.12.2010 16:21:28): child process received termination signal (15).
logger (15.12.2010 16:21:29): parent process received termination signal (15).
logger (15.12.2010 16:21:29): child process received termination signal (15).
logger (15.12.2010 16:22:22): data logger (version 4.6u, build 205) started.
logger (15.12.2010 16:22:24): connect station 0 (Vantage via USB serial).
logger (15.12.2010 16:22:25): station 0 (Vantage), wakeup sent.
logger (15.12.2010 16:22:25): station 0 (Vantage), syncing.
logger (15.12.2010 16:22:25): station 0 (Vantage), gettime request sent.
logger (15.12.2010 16:22:35): station 0 (Vantage), gettime request sent.
logger (15.12.2010 16:22:45): station 0 (Vantage), gettime request sent.
System info
Linux Kernel: 2.6.21.7 266 BogoMIPS, 30 MB RAM, NSLU2 (266 MHz)
MeteoHub: 4.6u (Build 205) ©2010 by Boris Pasternak, info@meteohub.de
System ID: WqcI1 Limited Demo Version, 47 days left
Network
Hostname: meteohub
Workgroup: HOME
MAC: 00:04:5A:0F:B4:A5
IP: 192.168.1.6
Gateway: 192.168.1.1
DNS: 192.168.1.1
WAN IP: ***.***.***.***
Storage
Swap: 0MB of 127MB used (0%)
System: 219MB of 402MB used (54%)
Data: 33MB of 1322MB used (2%)
Date and Time
UTC: 15.12.2010 14:29:28
Time Zone: Europe/Helsinki
Local Time: 15.12.2010 16:29:28
Uptime: 0 hours, 7 minutes
System Load: 0.05, 0.20, 0.14
Process
Weather Data Logging: running (last data: never)
SSH Login: running
SMB Shares: running
Posted: Thu Dec 16, 2010 1:22 am
please read this: http://wiki.meteohub.de/Setup_Guide
Your station/sensors are not configured correctly.
