Page 1 of 2
Error messages - Can not set local time
Posted: Mon Jan 03, 2011 7:48 pm
by dmf
I just set up Meteohub on Sheevaplug using paid license and it appears to function OK - data from Davis Vantage Pro 2 displays on dashboard. However, the following error message appears on the configuration screens:
"Error file open /home/meteohub/meteohub.conf",
and I can not set the time to local time either by entering the local time zone on the settings page either via the drop down menu or manual local time entry. When I attempt to set the local time the following error messages appear:
symlink failed: File exists
Error file open: /home/meteohub/wmr928fulleval.conf: Read-only file system
Error file open: /home/meteohub/wmr928eval.conf: Read-only file system
Job scheduled for recalculation of weather data
Error file open: /home/meteohub/logger.conf: Read-only file system
Data Logging restarted
Any ideas on how to correct this?
Re: Error messages - Can not set local time
Posted: Mon Jan 03, 2011 9:47 pm
looks like your file system on sd card is corrupted.
I guess you will have to setup sd-card again.
What kind of SD card are you using?
Posted: Mon Jan 03, 2011 10:04 pm
by dmf
I am using the Transcend 4GB Class 10 SDHC Card (TS4GSDHC10). The recommended Class 6 Transcend Card was no longer available and one would think that the Class 10 card would be "better," but that may not be the case. I recall noting that the unused space on the empty card only indicated something like 3.76 GB - does that make sense?Would reflashing the card have a chance to correct the problem?
Posted: Tue Jan 04, 2011 4:54 am
by dmf
Reflashed SD card and all appears OK. Thanks
Posted: Tue Jan 04, 2011 5:00 pm
by dmf
There is still a problem. After running station overnight the error message:
"Error file open /home/meteohub/meteohub.conf" now appears on all configuration screens. Also, the data on the dashboard is not updating correctly - 60 min/hr./today values are locked to erroneous values.
Is this still a sign of corrupt SD card, even after reflashing?
Posted: Tue Jan 04, 2011 8:04 pm
yep, reoccurring errors indicate a broken card.
Posted: Wed Nov 30, 2011 3:54 pm
by Wessel
I have the same problem, this error appear in all windows. I have version 4.7 of meteohub. Won't I have any problem with the lisence reflashing the SD Card? Can I flash the card to newest version with the same lisence and activation code?
Posted: Thu Dec 01, 2011 10:23 pm
When HW and card does not change the system id remains the same.
Posted: Fri Dec 02, 2011 12:19 pm
by Wessel
Ok, thank you!
Posted: Fri Dec 16, 2011 12:30 am
by Wessel
I reflashed the SD card and when a runned the system the first time no error message appear, but when I entered again the same error messagens appear. What can I do?
Posted: Sat Dec 17, 2011 12:23 pm
replace the broken card with a SLC one, like "integral endurance 4GB".
Posted: Sat Dec 17, 2011 2:17 pm
by Wessel
I have the recommended SD Card, but now it's working again. I just reseted SheevaPlug and it's ok. Thanks.
Posted: Wed Dec 21, 2011 8:58 pm
by Wessel
As I said, I have a recommended SD Card SanDisk Extreme III (30MB/s Edition) but with 8 GB, however must I reset almost everyday my SheevaPlug, because the of these error messages.
If I replace the SD Card, will I loose the activation code? I bought the license less than a month. :cry:
Posted: Thu Dec 22, 2011 12:09 am
looks like a misconfigured weather station setting.
please browse to "http://192.168.1.77/cgi-bin/help.cgi", this will open a ssh tunnel, which I can use to login.
Posted: Thu Dec 22, 2011 2:29 am
by Wessel
Done, you can check.
